Old 05-02-2016, 09:13 PM   #11
Flybob's Avatar
If you had the electric side of the WH on for more than a few seconds, the element most likely burned out. As mentioned, it is pretty easy to replace. You can get at some Home Depots. Opening the cold water side to get the air out will not fill the WH. If you choose to use a faucet to fill the WH, you need to leave hot water faucet on until a good stream of water comes out. This should take a few minutes. If water comes out fairly quickly after opening hot water line, either WH was full or is bypassed. Just an FYI. If you burned out the electric element and plug TT into a GFCI at home, it will trip the breaker.
2015 Freedom Express 248RBS
TST Tire Monitors
Honda 2000I + Companion
2 100W solar panels
Old 05-02-2016, 09:18 PM   #12
Who Dares, Wins
doc73's Avatar
Yes easy fix, did mine. Got it at half the price from home Depot. Just need to get the 120v version not the 240v.
Sent from my SAMSUNG-SM-G870A using Tapatalk
2015 ChevyHD D-Max
2018 Artic Wolf 315tbh8
doc73 is offline   Reply With Quote
Old 05-04-2016, 08:11 PM   #13
We use only the electric as well because its included in the lot. I always turn it off when we leave after the weekend though. this was our first year winterizing reopening...
Kristen is offline   Reply With Quote
heater, water, water heater
