Old 04-30-2016, 07:19 PM   #1
water heater issue
Please help, not sure I understand the bypass system for water heater and I'm not sure if I burnt up my electric element. we have a sandpiper 36bhok 5 th wheel... we had service guy winterize it. ..went and opened it today. .turned water on and water heater. ..didn't realize there was a bypass. Went back out about an hour later and turned heater back off...and then found bypass...is a big red handle inside main water area and tank dump handle area. ...turned it. ..heard water rush to heater. .went inside and ran all air out of line (does this run air out of tank too? ) then turned heater back on and no hot water after almost 45 min. is there another bypass? or have we burned element out? didn't try propane...just electric as we needed to head home from our seasonal lot. any advice? Thanks in advance!
Kristen is offline   Reply With Quote
Old 04-30-2016, 07:31 PM   #2
brookstone345sa's Avatar
It is possible that you burnt up element. Do you know what type of water heater, atwood or suburban?
Before you pull anything apart, I would check all fuses and breakers. It's possible that it just popped breaker.
You can burp your water lines by running water,but first fill after de-winterizing I like to use the blow-by valve located outside in heater compartment, just lift enough to allow water to run out and that helps to bleed air out.
Also, it takes longer to get hot water using electric
brookstone345sa is offline   Reply With Quote
Old 04-30-2016, 11:35 PM   #3
Is your trailer plugged into an electrical outlet? Somebody correct me if I'm wrong, but I don't think the water heater will work on electric with just battery power. If the trailer was plugged in, then it's very possible you have a burnt element.
dstacy969 is offline   Reply With Quote
Old 05-01-2016, 01:09 AM   #4
bikendan's Avatar
Yes, you are correct.
The WH's electric side is 120v AC only and won't work on 12v DC battery power.
Dan-Retired Firefighter/EMT
Equalizer WDH and Prodigy BC
Old 05-01-2016, 07:25 AM   #5
Yes it is plugged in
Old 05-02-2016, 12:46 PM   #6
Water Heater issue
Kristen.
I just had the same experience.
If your water heater is a Suburban brand,,...the heater element is easy to change out,...and the part number may be 520789..you'll have to verify.
My model type is SW-DE..
Here's a link for the replacement instructions
Randy and Nicole is offline   Reply With Quote
Old 05-02-2016, 12:56 PM   #7
TURBS's Avatar
A very good example of why you should use the water heater pressure relief valve to make sure tank is full before turning it on.
2008 2500hd Duramax
2015 Columbus 320RS
2016 nights camped "2"
2015 nights camped "34"
Old 05-02-2016, 06:37 PM   #8
Very true....
My 1st time de-winterizing...and the checklist I had didn't even mention it.
I went back online and got a more complete education !
Old 05-02-2016, 06:53 PM   #9
Georgia Frog Rally 2018
aceinspp's Avatar
2008 2500hd Duramax
2015 Columbus 320RS
X 2 on the other hand why use the electric side. I have never used it for 2 reasons. One can burn out element and two gas works just fine. Later RJD
2015 Chevy 2500 6.0 4:10 gearing.
Days camped in 2016 58
Days camped 2017 62
Days camped 2018 18
Old 05-02-2016, 08:58 PM   #10
I use my electric almost all the time because the H/W cost is included in the camp site and I don't have to get propane as often. It has been on more than 700 days and the element hasn't burnt out. If it ever does, I will use propane till I can get a new one.
2010 F250 5.4L 3.73
2011 Flagstaff 831FKBSS
Equal-i-zer 4pt 12K
2010 F250 4X4 5.4L 3.73 LS
EQUALIZER E4 1200/12000
heater, water, water heater
