Old 09-19-2016, 09:25 AM   #1
water heater melting taillight sonomo 280RKS
Owned this trailer for just over a month. Noticed this weekend that the water heater exhaust is melting the taillight cover and the plate. tough to see but if you look at the bottom middle of the light cover you can see the distortion. when i barely touched it it was hot as hades. Anyone seen this before on other trailers or resolutions? i mean, I suppose a heat shield of some sort but this really just seems like a design flaw. Also, what if this thing fires up in the night in the back of the trailer, and i'm in the front of it asleep? Any thoughts welcome.
Name:	melted tailight.jpg
sullybeav is offline   Reply With Quote
Old 09-19-2016, 10:18 AM   #2
Head Rambler
They picked a bad place to install that heater.
I'd definitely install some kind of aluminum shield across the top of that exhaust screen. You could attach it with either pop rivets or small bolts.
Salem 29RKSS Pushing a 2500 Mega-Cab CTD!
Gotta go campin!
Old 09-19-2016, 10:22 AM   #3
WOW! That is a pee poor design.
That exhaust gets pretty hot.
Looks like you're going to need to fabricate some kind of shield/deflector and put under the light.
2016 Flagstaff 8529IKBS Diamond Package 5th Wheel
Ford F-Series SCREW 4x4
TST Tire Monitor - Sinemate 3500w Gen.
Nights Camped: '15 = 22'16 = 46
Old 09-19-2016, 10:25 AM   #4
wmtire's Avatar
I agree that this seems to be a design flaw that FR should be made aware of.
If you have a dual powered water heater (propane and electric), you may want to run it on electric only if possible, until a solution is found.
2011 Flagstaff 831 RLBSS
Real men don't eat honey. Real men chew on bees.
Old 09-19-2016, 10:47 AM   #5
raspivey's Avatar
Wow...that's engineering, lol. Sometimes they don't think things through very well. My MiniLite had the outside shower a few feet in front of the power connection. To use it, you'd have to be standing on top of the power cord in a puddle of water.
2012 Chevy Tahoe LTZ - HD tow package
Old 09-19-2016, 11:03 AM   #6
Brother Les's Avatar
call dealer now and tell him problem and for him/FR to come up with a fix.... do not let them off and this is a very large hazard that will not go away. if it is melting the cover, all the wires are also may get hot and brittle.
Brother Les
Old 09-19-2016, 11:06 AM   #7
Georgia Frog Rally 2017
aceinspp's Avatar
Somebody sure was not thinking when they put the heater where it is. I'd use the electric side if installed till you come up with a solution. I would also contact FR for advice. Later RJD
2015 Chevy 2500 6.0 4:10 gearing.
Days camped in 2016 58
Days camped so far 2017 15
Days booked so far in 2017 37
Old 09-19-2016, 11:57 AM   #8
Originally Posted by Brother Les View Post
.....call dealer now and tell him problem and for him/FR to come up with a fix.... do not let them off .........
X2
2007 Surveyor SV230
- 200 Watts Solar/MPPT Controller - 230 AH Battery Bank - 600 watt PSW Inverter - (2) 2000 watt Inverter Generators - LED Lighting - Boon Docking 99% of the time.
2009 F150 - 5.4 Litre - 6 speed - Tow Package
boondocking is offline   Reply With Quote
Old 09-19-2016, 04:38 PM   #9
DouglasReid's Avatar
Aside from the fact that the design is PI-S Poor Id get a piece of sheet metal and install ie under the taillight cover.
Make it hang down 1/2" or so below the cover and bend it 80 degrees or so. It should hang past the rear edge of the taillight cover an additional inch. It will deflect the heat and prevent it from reaching the plastic lens cover and keep it from melting.
Id use aluminum or galvanized flashing so it won't rust.
Easy fix for a moron's design flaw.
Maurice, LA
2012 Wildcat Sterling 32RL
2008 Chevy Silverado 2500HD LT Diesel
TST TPMS system w/ Flow-thru sensors
2001 Cougar 281 EFS (sold)
DouglasReid is offline   Reply With Quote
Old 09-19-2016, 04:55 PM   #10
Iwannacamp's Avatar
LOL X2 I was gonna suggest this. Careful that the siding isn't getting too hot also.
2017 Puma 297RLSS
2005 Ram 2500 4X4 diesel
Our new 5er 10-26-16
Days camped 2016 8 2017 1
280, heater, light, water, water heater
