Old 03-30-2016, 08:58 PM   #1
Water heater on/off switch
Every RV that I've owned has the water heater switch in the worst possible location. You have to open the panel and reach around the little pipe with your finger to turn it on and off. Why they couldn't have put the switch in an easy to access location is beyond me, but I'm thinking about doing just that. I have astorage exterior storage compartment next to my water heater where I could put a lighted switch. The light would also remind me to turn it off as I'm putting stuff away during camp breakdown. Has anyone one else done this sort of thing? If so where did you put it? Was it difficult? Any photos would be awesome.
2015 Rockwood 8315 BSS
2015 Silverado 2500HD 6.0
Ginger & Sammie (our 4 legged kids)
US Navy veteran
Movike is offline   Reply With Quote
Old 03-30-2016, 08:59 PM   #2
wmtire's Avatar
I think there are several threads in the modifications subforum, that show how others have accomplished this.
edit: here are a few
Water Heater Switch with Power-on Light
Added Inside Switch for Water Heater
2011 Flagstaff 831 RLBSS
I hate it when people don't know the difference between ur and u'r!
Old 03-30-2016, 09:08 PM   #3
Blackhat6mike's Avatar
My water heater main electrical on/off switch is inside the rear panel to the heater and can be easily reached by removing the outside vent panel. However, we never turn it off. If we wanted to turn it off [electricly] we would use the breaker in the main breaker box in the hallway. No need to turn off the switch outside.
The gas switch is in the bathroom and easy to flip on/off to use either as a primary source of heat, or to assist the electrical elements.
Aviator Wright Flyer #1919
Army Pathfinder Vietnam, 3 tours
DAV, MOPH, VFW, NRA, 1stCav. ABN
Blackhat6mike is offline   Reply With Quote
Old 03-31-2016, 03:28 AM   #4
Doh!, my bad. Thanks for the links, I'll check them out.
US Navy veteran
Old 03-31-2016, 11:37 AM   #5
MilCop4523's Avatar
i INSTALLED A SPLIT BREAKER AND ENSURE ITS OFF AT THE TANK AND THE PANEL UNTIL ITS FULL OF WATER AND THEN THE SWITCH OUTSIDE ON THE UNIT IS TURNED ON LAST.
TV 2018 Ford F250, hauling a 2018 KZ 331 TH 12 Sportster 5th wheel, packing a 2015 CF MOTO 800 U-Force SXS
MilCop4523 is offline   Reply With Quote
Old 03-31-2016, 11:53 AM   #6
I don't know why it never occurred to me to turn it on and off with the breaker, duh. I've complained for years about the inconvenient location of the switch, and there's been a few times that I almost forgot to turn it off because of the out of site and out of mind location. I still think I'll put a lighted switch inside of the outside storage compartment. That way as I'm putting stuff away, the light will be a reminder to turn it off. I can still see myself forgetting to turn off the breaker.
US Navy veteran
Old 03-31-2016, 12:54 PM   #7
milvet33's Avatar
Circuit breaker seems to be the best way to go. The little switch on my RV is the same as yours and it was starting to stick and I didn't even want to think about trying to replace it. I just added the breaker to my preflight check list.
milvet33 is offline   Reply With Quote
Old 03-31-2016, 12:59 PM   #8
Heater Switch
yes I had the same problem especially after leaving the power on after I emptied the tank. I just rewired the small switch to inside the bathroom area with a small lighted switch
Angels is offline   Reply With Quote
Old 03-31-2016, 02:34 PM   #9
slipf18's Avatar
HW heater switch
As a doctor, I have had less difficult surgeries than trying to insert that cotter pin into the hot water heater on/off switch....sigh.
2017Winnebago 2500RL, Hobie Odyssey
Ram 2500 with 6.7l Cummins turbo diesel
Blue Ox 1500 WDH
Barker 3500 Tongue Jack
DW & a feisty Border Terrier named Painter
slipf18 is offline   Reply With Quote
Old 03-31-2016, 02:40 PM   #10
Georgia Rally Coordinator
aceinspp's Avatar
Ha as many campers I've had never use the electric. Rather use the propane. Later RJD
2018 Dodge Ram 2500 6.4 3:73 gearing. Traded 2015 Chevy 2500 6.0, 4:10 gear
Days camped in 2016 58
Days camped 2017 62
Days camped 2018 67
aceinspp is online now   Reply With Quote
heater, water, water heater
