Old 07-16-2015, 07:11 PM   #1
340_Formula_S's Avatar
Water heater operation.
I need some help understanding the operation of my water heater. The unit is a 12 gallon Suburban with DSI. If I have the DSI switch in the on position, does the unit switch automatically from electric to gas or vice versa? I only have one water heater switch on my interior control panel. My old TT was also a DSI unit but it had a gas switch and an electric switch. Some knowledge on this would be appreciated.
Elko, Va.
2012 Ram 3500 DRW Cummins High Output
2012 Cedar Creek 36B2
340_Formula_S is offline   Reply With Quote
Old 07-16-2015, 07:20 PM   #2
IF it has a 110v mode of operation, the switch will be outside in the water heater compartment.
Old 07-16-2015, 07:28 PM   #3
Georgia Frog Rally 2018
aceinspp's Avatar
X 2 Later RJD
2018 Dodge Ram 2500 6.4 3:73 gearing.
Days camped in 2016 58
Days camped 2017 62
Days camped 2018 18
Old 07-16-2015, 07:43 PM   #4
So the switch outside is for electric operation and the switch on the interior panel is for gas?
Elko, Va.
Old 07-16-2015, 07:53 PM   #5
elrand's Avatar
Correct
if your using the electric heat you can turn on the gas for faster recovery just remember to turn off the electric heat if your draining the water heater
2015 Cedar Creek Silverback 33IK
elrand is offline   Reply With Quote
Old 07-16-2015, 08:05 PM   #6
Thank you.
Elko, Va.
heater, water, water heater
