Old 04-17-2016, 07:00 AM   #11
satdog01's Avatar
X2 on the Oxgenics shower head, does streach the hot water supply. Also bumped up the high limit temp in the tank which was the better water stretcher.
Marriot II on Wheels 2017 Flagstaff Classic 832OKBS Diamond Pkg
2013 GMC Denali crew 6.6L 2500 HD DMAX w\Alison Trans
Pepper 🌶 Pomeranian rescue 204 nights as camping buddy
Days camped in FR, 2011 = 20, 2012 = 57, 2013 = 59
....2014 = 39, 15 = 52, 16 = 77, 17 = 81, 2018 = 4
Retired :
satdog01 is offline   Reply With Quote
Old 04-17-2016, 08:18 AM   #12
How is that done?
2016 Rockwood Signature Ultralight 8329SS Platinum
2016 GMC Sierra 2500HD Denali Crew Cab Duramax
TXFolkie is offline   Reply With Quote
Old 04-17-2016, 08:25 AM   #13
john5646's Avatar
X2 on limit, if you can explain I just went and looked at mine maybe newer one are different. ?
john5646 is online now   Reply With Quote
Old 04-17-2016, 08:54 AM   #14
From experience that little switch on the water heater itself will self destruct rather quickly. I found it better to leave the switch on and turn off 120VAC at the breaker.
donniedu is online now   Reply With Quote
Old 04-17-2016, 02:33 PM   #15
satdog01's Avatar
Re heater element upgrade. There was a post on it back a ways, went from 1440 to a 1500 or so. Easy change out that means using more cold water to hot water mix. Hot water last longer as flow rate is reduced while showering. Got higher wattage element fron Internet rv dealer after reading post last year.
Retired :
Old 04-18-2016, 09:17 AM   #16
Be very careful - be very careful using the valve in the shower head for a GI shower, there are no check valves on either hot or cold water lines in the shower, hot water tends to back up in the cold water line. Some RV hot water tanks temperatures are over 150 degrees (scalding hot - been there done that).
DJsFolly
D. J. Schuler is offline   Reply With Quote
Old 04-18-2016, 09:30 AM   #17
TURBS's Avatar
Originally Posted by V-Lite Fun View Post
I just installed an Oxygenics shower head. It's worth every penny. You have more pressure and it stretches the water. The shutoff is handy also.
In Youroo's testing, the oxygenics shower head used MORE water the the factory supplied shower head.
Sorry
heater, suburban, water, water heater
