Old 07-17-2015, 03:18 PM   #1
Send a message via ICQ to sular47
Water Heater will not work on gas or electric
Replaced the Hi--Tstat switch and still no hot water. Will not operate on gas either! Any suggestions?
sular47 is offline   Reply With Quote
Old 07-17-2015, 03:29 PM   #2
wmtire's Avatar
Howdy Sular, your initial post is kinda vague. We need some more details on EXACTLY what you are doing to turn on the water heater...either on the propane or electric heating element side (if equipped). It would greatly help us in the troubleshooting to know what brand/model water heater you have too.
Have you verified that you don't have hot water at the tank, or are just turning on the hot water taps (which won't do you any good, if the bypass valves are still in the winterization mode).
Thanks, and hopefully with more information, the great members here can get you lined out.
This previous post of mine here, has more information on the bypass valves, as well as a link to the operation of the common Suburban brand water heater. There are better posts from members, but I just knew how to easily access this one.
Water heater won't fill
2011 Flagstaff 831 RLBSS
Iíve lost my scapegoat.
Old 07-17-2015, 04:03 PM   #3
Well, do I feel like a idiot. I went to your water valve position post and I had the valves in the wrong position. Thank you!!!!!!!!!
electric, gas, heater, water, water heater
