Old 03-14-2014, 04:54 PM   #1
Weatherproof RJ45 Connector
Hi, I have finally got fed up with poking the two coax cables from the Satellite dish through the weatherstripping at the side of the slide out. I have installed an outdoor connection box on, the rear of our Sabre, with 2 F connectors inside. This works great. I am now looking to do a similar thing with the ethernet cable that comes from the external portion of my WiFi ranger setup. Only problem is that I can't find a weather proof flush mounting box with an RJ45 connector inside. Does any one know a source for one of these?
Barry
ex-egll is offline   Reply With Quote
Old 03-14-2014, 05:02 PM   #2
Kaadk's Avatar
When I ran my Cat-5 in the old house, I used those little snap in blocks. (See here)
Not exactly waterproof, so you'd still need a cover, but you're probably going to want a cover anyways, those connectors can be susceptible to corrosion.
roo, roof
