Old 06-27-2019, 07:33 PM   #1
Web/Remote HVAC thermostat?
I have a Dometic rooftop HVAC unit. I would like to be able to adjust the temp remotely so that I don't return to a hotbox. Does anyone know of a replacement thermostat that could hook to wifi and allow remote temp adjustments from a phone ap?
John Hines is offline   Reply With Quote
Old 06-27-2019, 07:48 PM   #2
Head Rambler
Which model year is it?
Does it have a digital thermostat or an old analog one?
If it has a digital one there is no WiFi thermostat that will work with it without some work, including pulling new thermostat wiring.
Gotta go campin!
Old 06-27-2019, 07:50 PM   #3
Lame *****
Why not just set it and run it? Are you on a meter?
Maggot
Maggot is offline   Reply With Quote
Old 06-27-2019, 07:57 PM   #4
Or swap old thermostat with a programmable one that you can set before you leave.
'18 Rockwood Roo 233S
Husky Centerline TS 800-1200lbs hitch
'18 GMC CC 4x4 SLT 1500 Sierra
Obazswm is offline   Reply With Quote
Old 06-27-2019, 08:09 PM   #5
Thanks for the reply. 2004 analog.
Old 06-27-2019, 08:13 PM   #6
Programmable is an option, but I would love to be able to alter the programming remotely.
Old 06-27-2019, 08:33 PM   #7
Head Rambler
You're in luck.
With that model you can find wifi thermostats that will work. You have to find one that doesn't require a C wire and one that will work with millivolt systems.
I haven't used it, but the Lux Geo wifi thermostat should work.
Gotta go campin!
Old 06-27-2019, 08:42 PM   #8
Perfect! Many thanks.
Old 06-28-2019, 08:38 AM   #9
The problem is you will need constant WiFi to adjust it remotely.
remote, thermostat
