Originally Posted by Quest0351
Have a 2007 Forest River pop-up with a WFCO 8725-P power converter... the converter appears to be producing too much voltage... I went outside today and found that my 12 volt battery was being cooked by the converter... when I put a meter on it, it showed 21 volts.
Any ideas would be appreciated...
Some would replace with the same thing. Many folks take this opportunity to upgrade to Progressive Dynamics to get better battery charging and longer battery life. Your call.
$147
https://www.rvupgradestore.com/WFCO-...-p/55-4720.htm
$99
https://www.adventurerv.net/wfco-amp...k-p-14339.html
2019 Ram Bighorn, CC/SB 2500 4x4 6.4L/8 Speed, Max Tow 14,460 lb/2,940 lb payload.
2019 F-150 King Ranch 3.5 Eco, 12,800 lb/1,546 payload.
2020 Coachmen Apex UL 289TBSS
2019 Quality Trailers 16'x7' 7K GVWR Utility Trailer
2019 IronBull 22'x102" 14K GVWR Equipment Trailer
