Old 01-12-2012, 10:43 AM   #1
HI to every one I am new to the forum any way my 2006 lexington 28/3 Lexington Ford V10 inverter does not seam to be charging any one got any Ideas what it cloud be We are from England but are in Benidorme Spian
Hi to every one I am so new to this we are From Yorkshire Englan and on vacation in Benidorm Spain in our 2006 Lexington 28/3 Ford V10 Every thing was gowing well untill The inverter WFCO 8935 stop working does any one know what it might be wrong with and how do i fix it
Regards all Rob and Lis
Rob240 is offline   Reply With Quote
Old 01-12-2012, 03:39 PM   #2
Herk7769's Avatar
Rob and Lis,
Her is the manual for your converter. It contains a trouble shooting section to help you determine if your WFCO converter is the problem.
Ground connections are always suspect in cases like yours, so if the converter is not charging your battery, you need to check the battery and its connections (including fuses) as well.
File Type: pdf Manual - Power Distribution Center WF-8900 English.pdf (1.89 MB, 114 views)
HAM CALLSIGN - KC3FFW
Old 01-13-2012, 03:35 AM   #3
Herk7769's Avatar
Additionally, a dead battery CAN NOT be charged with the converter.
You must remove it (them) and use a car charger to bring it (them) up to full charge and reinstall it (them).
The reason is a dead battery looks to the converter like a dead short and will shut it down to prevent overload in the converter.
Old 01-13-2012, 07:10 AM   #4
Hi Lou and Laura
We bought the RV new when we when to pick it up they give us demo the full works they showed us the Half time oven /microwave/covension we took the RV home never useing the oven 2 years later we tryed it It light up and then died there must be some one in beacuse the microwave works with any lights do kown any thing about them
Very Best Regards Rob & Lis
Old 01-13-2012, 08:57 AM   #5
Herk7769's Avatar
Originally Posted by Rob240 View Post
Hi Lou and Laura
We bought the RV new when we when to pick it up they give us demo the full works they showed us the Half time oven /microwave/conversion we took the RV home never using the oven 2 years later we tried it It light up and then died there must be some one in because the microwave works with any lights do known any thing about them
So this is a different issue that the WFCO converter issue?
Old 01-13-2012, 10:00 AM   #6
Hi say competely diffrent we realy have not missed the oven at all .We have travled all Europe for the last 6 years and have any real big issues with the Lexington and no at all with the Ford so we can not complain I my trying to post some Photos for the Forum but up to now on succses I will Keep trying
Regards Ro & Lis
Old 01-13-2012, 10:15 AM   #7
Herk7769's Avatar
There is a little paperclip on the top like of the advanced menu.
Click on the paperclip and then "browse" for the JPG photo (or other supported file type - watch limit on the size of the photo).
Then click upload to embed the photo in your post.
Old 01-13-2012, 11:15 AM   #8
Don't call me Junior!!!
I had the same problem with my set-up. Discovered it was not the TT but the TV. On my model TV the battery feed wire is not hooked up at the factory. On my TV it was a matter of simply bolting the supply wire to the fuse box and problem solved. Just a thought for you.
2012 Tracer Executive 2600RLS
2011 Chevy Tahoe HD Towing Pkg
BubbaTex is offline   Reply With Quote
Old 01-13-2012, 11:23 AM   #9
Herk7769's Avatar
I am not at all familiar with Class C motor home wiring and charging circuits. Perhaps an owner of a similar coach might chime in.
Old 01-13-2012, 11:25 AM   #10
Originally Posted by herk7769 View Post
I am not at all familiar with Class B motor home wiring and charging circuits. Perhaps an owner of a similar coach might chime in.
Doh! the small details one misses. Sorry bout that.
