Old 11-01-2010, 07:15 PM   #1
What are these Concertone inputs?
If this is the wrong forum please move.
Can you fine people tell me what all the imputs can be used for. I don't think that they are Concertone I think that they were added by Forest River but I may be wrong. These inputs are in a shelf directly under the TV and to the side of the Concertone unit. And one more thing. We just spent a week in the RV and I looked through all the paperwork that came with the RV and there is no referance to these inputs. I was trying to get broadcast TV to play through surround sound with no success.
slides is offline   Reply With Quote
Old 11-02-2010, 05:35 AM   #2
Welcome to the Forum,
To be honest, I think the only way you are going to find the true answer is to access the wires behind the jacks and the wires behind the Concertone. Gently tug on each wire and locate the other end. Each wire is on a lable on the back of the Concertone. Have a label maker handy. Label each end of the wires, along with the face of the jacks. This will save you time in the future. Good luck!
Kirk, KN1B
2013 Cardinal 3800FL
2009 GMC 3500HD CC LB SRW
kbrown1075 is offline   Reply With Quote
Old 11-02-2010, 08:52 AM   #3
BigDTx's Avatar
Ipod, mp3, aux??? video game? can you post some pics so we can see what the inputs look like?
BigDTx is offline   Reply With Quote
Old 11-02-2010, 08:54 AM   #4
On mine, the headphone jack input on the back of my TV supplies the sound to the Concertone ZX600, and that must be on input 2, then you choose which speakers, A, B or C on the Concertone that you want. You also must use 2 remotes; one for the TV, and one for the Concertone. My TV is a 12 volt Venturer 22" HDTV. Hope this helps, Randy
Old 11-02-2010, 06:44 PM   #5
joy-rick's Avatar
I have a ZX500 in my 2007 Flagstaff 831BHSS and so that might be somewhat different than the ZX600 that you are talking about. But, I'll ask anyway. Where on the Concertone do you plug in the sound cable from the TV? On one of the wall plates, or somewhere on the back of the Concertone?
Thanks for your assistance.
Rick
joy-rick is offline   Reply With Quote
Old 11-02-2010, 09:12 PM   #6
Wanna Be Camper
SaskCampers's Avatar
I have a 2011 Flagstaff and with a 32" Toshiba TV and it does not feed the ZX700 at all. In our case we would have to add a set of cables from the audio out on the TV to one of the spare inputs on the ZX. I can't be bothered with setting it up as the TV sounds fine IMO without using the ZX.
John & Deb
2011 Flagstaff V-Lite 30WRLS
Old 11-03-2010, 04:33 AM   #7
We have a 2011 Flagstaff and we also had to add a RCA plug type cable from the audio out of the TV to an Audio input on the Concertone. I to have to use 2 remotes. In time, this will be resolved by replacing the TV to one that has a fixed audio out or an option to set it to fixed audio out. Check the audio menu in your TVs, you might have the option for fixed audio out.
Kirk, KN1B
Old 11-03-2010, 07:17 AM   #8
How about submitting some pictures? kbrown1075 do you have the upgraded surroundsound system or standard TV? Just wonduring why no cables unless FR didn't intend the usuer to use the concertone for audio, although I guess that doens't make sense as, isn't the concertone also the dvd player?
2009 F150 SCREW4x4 Prodigy P3 and tow package Valley WDH and dual anti sway
2006 Party Barge 21 90 Merc Optimax
2011 RockWood 2702 SS arrived 11.10.2010
nights camped 2010 6
threegr8katz is offline   Reply With Quote
Old 11-03-2010, 07:32 AM   #9
MtnGuy's Avatar
Rick
I found my audio hookups on the back of my Concertone ZX50. If the ain't on front, and the display shows an auxiliary mode, then you probably have connections in the back.
Old 11-03-2010, 11:30 AM   #10
Wanna Be Camper
Concertone® Product Gallery
If you scroll about 3/4 of the way down the page it shows the panels FR uses. We have the one that has a game a VCR and straight audio inputs on it and it is in the cabinet under the TV. You need to put the ZX unit on either Aux 1 or 2 to activate that input panel. All that info was in the manual for our trailer. And there is also a spare set of inputs that you have to pull the ZX head unit out to access.
John & Deb
Old 11-03-2010, 02:49 PM   #11
The Old Man
Willis's Avatar
Thanks for that link...in case anyone might be remotely interested, here's what I have on my 2010 Flagstaff 829RGSS:
Still to go: AK, NL, NT, NU, YT
Willis is offline   Reply With Quote
Old 11-03-2010, 03:02 PM   #12
Grape Escape
those are aux inputs for such things as playstation, camera, VCR, audio such as Ipod etc.
2008 Cardinal 30RKLE 5th wheel sold
2006 Rockwood 2607, 2001 Traillite
55 nights 2009, 53 for 2010
44 for 2011, 38 for 2012, 35 for 2013, 51 for 2014
dezolen is offline   Reply With Quote
Old 11-03-2010, 05:38 PM   #13
The Old Man
Willis's Avatar
Correct...and you can use the two jacks on the right to supply sound from the TV to the CT and speakers. Also, you can use these jacks to hook up the sound output from external DVD or Bluray and then use HDMI to get HD on the display which you don't get from the CT unit.
Old 11-03-2010, 05:49 PM   #14
Here are some pics. This is where the audio out of the TV are (Red and White). The yellow goes down to a wall plate that connects the Video out of the Concertone allowing the DVD video to get to the TV. I can unplug this and connect to a Sat receiver of VCR, etc. but there is no audio to the Concertone or TV for the SAT or VCR. I have to correct that at some point. The audio out of the TV (Red & White) are connected to input 2 on the back of the Concertone. Problem is that you have to turn the TV all the way up and the Concertone has to be turned up pretty loud to hear the Concertone speakers over the TV speakers. The current system setup is much less than desirable. Being a past Audio Video Tech, I can make this better!! I need to save some space as the DW and I are Amateur Radio Radio operators and plan on some radios in the space under the TV. It will be sometime over the winter when I "redesign" the current system. Only equipment I foresee changing is the TV to a TV with a fixed audio output (so the volume control of the TV would have no effect on the Concertone, it would be a constant level). I hope the pictures make it.
ID:	3784   Click image for larger version
ID:	3785   Click image for larger version
ID:	3786   Click image for larger version
Kirk, KN1B
Old 11-04-2010, 10:48 AM   #15
Villa Estate 392FLFB
The_Stuff's Avatar
wish my tv had that audio out.. damn cheap walmart pos lol!
One state/province at a time!
The_Stuff is offline   Reply With Quote
Old 11-04-2010, 10:52 AM   #16
The_Stuff's Avatar
just wish there was 4 sets of cable ran to the concertone instead!! all the wires in the selector box go over to the concertone and then it only uses 1 set of wires to hook in it! there is au1 au2 and av1 not used! mine is plugged all into av2.
Old 11-17-2010, 02:48 PM   #17
joy-rick's Avatar
I just though I'd update my previous post. Joy and I recently purchased a Dynex 26" LCD flat screen from Best Buy ($234) for our Flagstaff 831BHSS. The TV came with a "red & white" audio cable. I connected this cable from the audio out jacks on the the TV to the AV2 connection on the wall panel for the Concertone. I then connected a "red, white & yellow" cable from the DVD player to the input jacks on the TV.
This setup works perfectly! The tone and volume from the Concertone is greatly superior to the internal speakers in the TV. When I fire up a 5.1 Dolby DVD the Concertone really sounds great!
The installation couldn't have been any simpler. Thanks for all those who responded.
Rick
Old 11-17-2010, 06:40 PM   #18
Herk7769's Avatar
My rats nest
Top two audio out to the Concertone.
The rest are inputs from:
Our desktop computer - PC
XBox Game machine - Component
HDMI - Upconverting DVD Player
Composite - from dvd and USB port in Concertone
Cable from Amp Control Panel
XBox is gone now (gave to grandkids) but there may be a Wii under the tree this year.
Lou & Freya the wonder dog
2019 Flagstaff 8529FL
Old 11-18-2010, 06:24 PM   #19
Owner - RVtronics
Bob Fields's Avatar
Send a message via AIM to Bob Fields Send a message via Skype™ to Bob Fields
Pictures really do speak a thousand words when trying to explain some of this stuff!
Glad to hear how you made out Rick!
Bob Fields
bob@rvtronics.com
www.rvtronics.com
(781) 281-9440
Bob Fields is offline   Reply With Quote
