Old 11-01-2010, 07:15 PM   #1
What are these Concertone inputs?
If this is the wrong forum please move.
Can you fine people tell me what all the imputs can be used for. I don't think that they are Concertone I think that they were added by Forest River but I may be wrong. These inputs are in a shelf directly under the TV and to the side of the Concertone unit. And one more thing. We just spent a week in the RV and I looked through all the paperwork that came with the RV and there is no referance to these inputs. I was trying to get broadcast TV to play through surround sound with no success.
slides is offline   Reply With Quote
Old 11-02-2010, 05:35 AM   #2
Welcome to the Forum,
To be honest, I think the only way you are going to find the true answer is to access the wires behind the jacks and the wires behind the Concertone. Gently tug on each wire and locate the other end. Each wire is on a lable on the back of the Concertone. Have a label maker handy. Label each end of the wires, along with the face of the jacks. This will save you time in the future. Good luck!
Kirk, KN1B
2013 Cardinal 3800FL
2009 GMC 3500HD CC LB SRW
kbrown1075 is offline   Reply With Quote
Old 11-02-2010, 08:52 AM   #3
BigDTx's Avatar
Ipod, mp3, aux??? video game? can you post some pics so we can see what the inputs look like?
BigDTx is offline   Reply With Quote
Old 11-02-2010, 08:54 AM   #4
On mine, the headphone jack input on the back of my TV supplies the sound to the Concertone ZX600, and that must be on input 2, then you choose which speakers, A, B or C on the Concertone that you want. You also must use 2 remotes; one for the TV, and one for the Concertone. My TV is a 12 volt Venturer 22" HDTV. Hope this helps, Randy
Old 11-02-2010, 06:44 PM   #5
joy-rick's Avatar
I have a ZX500 in my 2007 Flagstaff 831BHSS and so that might be somewhat different than the ZX600 that you are talking about. But, I'll ask anyway. Where on the Concertone do you plug in the sound cable from the TV? On one of the wall plates, or somewhere on the back of the Concertone?
Thanks for your assistance.
Rick
joy-rick is offline   Reply With Quote
Old 11-02-2010, 09:12 PM   #6
Wanna Be Camper
SaskCampers's Avatar
I have a 2011 Flagstaff and with a 32" Toshiba TV and it does not feed the ZX700 at all. In our case we would have to add a set of cables from the audio out on the TV to one of the spare inputs on the ZX. I can't be bothered with setting it up as the TV sounds fine IMO without using the ZX.
John & Deb
2011 Flagstaff V-Lite 30WRLS
Days Camped 2016: 3 2017: 0
Old 11-03-2010, 04:33 AM   #7
We have a 2011 Flagstaff and we also had to add a RCA plug type cable from the audio out of the TV to an Audio input on the Concertone. I to have to use 2 remotes. In time, this will be resolved by replacing the TV to one that has a fixed audio out or an option to set it to fixed audio out. Check the audio menu in your TVs, you might have the option for fixed audio out.
Kirk, KN1B
Old 11-03-2010, 07:17 AM   #8
How about submitting some pictures? kbrown1075 do you have the upgraded surroundsound system or standard TV? Just wonduring why no cables unless FR didn't intend the usuer to use the concertone for audio, although I guess that doens't make sense as, isn't the concertone also the dvd player?
2009 F150 SCREW4x4 Prodigy P3 and tow package Valley WDH and dual anti sway
2006 Party Barge 21 90 Merc Optimax
2011 RockWood 2702 SS arrived 11.10.2010
nights camped 2010 6
threegr8katz is offline   Reply With Quote
Old 11-03-2010, 07:32 AM   #9
MtnGuy's Avatar
Rick
I found my audio hookups on the back of my Concertone ZX50. If the ain't on front, and the display shows an auxiliary mode, then you probably have connections in the back.
Old 11-03-2010, 11:30 AM   #10
Wanna Be Camper
Concertone® Product Gallery
If you scroll about 3/4 of the way down the page it shows the panels FR uses. We have the one that has a game a VCR and straight audio inputs on it and it is in the cabinet under the TV. You need to put the ZX unit on either Aux 1 or 2 to activate that input panel. All that info was in the manual for our trailer. And there is also a spare set of inputs that you have to pull the ZX head unit out to access.
John & Deb
