Old 06-23-2014, 10:57 PM   #1
What kind of Inverter to run my AC
New camper owner here. I just purchased a Cherokee 264BH a few days ago. I would like to know what I would need for an inverter to run my AC. The dealer said at least 3500 Watts would be needed. I have a couple of questions:
  • Anybody use the Champion brand inverters? Are they quiet and are they good?
  • Can I get 2 of the 2000 Watt models and link them together, to run my camper and AC?
Oakster is offline   Reply With Quote
Old 06-23-2014, 11:28 PM   #2
TigerPride
cajunrvr's Avatar
Put fridge and hot water on propane ran everything else on 3000wt honda for four straight days no problems
cajunrvr is offline   Reply With Quote
Old 06-24-2014, 02:42 AM   #3
bikendan's Avatar
Oakster, you need to add "generator" after inverter.
just saying "inverter" means something different.
you're talking about an inverter generator.
you need to post what size a/c you're talking about.
generally, a paralleled pair of 2000w inverter generators SHOULD be able to run a 13.5k or 15k a/c.
Dan-Retired Firefighter/EMT
Equalizer WDH and Prodigy BC
Old 06-24-2014, 03:25 AM   #4
Witch Doctor's Avatar
Your start up will be a problem, you should add a hard start kit to your list.
Rockwood #8289 WS 2012
F250 6.0 / Husky 16k
With 4 point leveling system
Old 06-24-2014, 05:05 AM   #5
AquaMan's Avatar
Don't know the size of your AC, but my 3000w Dometic inverter generator will run my 13.5k AC along with lights and 2 fridges just fine. I can also run both AC's, 2 fridges, lights, and tv's on a 30amp hookup, though. Both ACs are without any modifications. I also have a Progressive Industries EMS, so I know I'm not running on a low voltage situation. If you're talking about using an inverter and a battery bank, don't think that the batteries would hold up long.
2016 Georgetown 364TS
2017 Jeep Rubicon Recon toad
Nights Camped 2018 - 7
inverter
