Old 02-24-2019, 02:27 PM   #1
JPin AZ's Avatar
What year did HD tv antennas start being installed?
I just bought a 2011 Roo 23SS and I am wondering if the antenna is HD. If not what suggestions do you have to get TV over the air?
JPin AZ is offline   Reply With Quote
Old 02-24-2019, 02:30 PM   #2
It's not the antenna but the
tv . the older TV's needed a box for the digital channels .
MR.M is offline   Reply With Quote
Old 02-24-2019, 02:42 PM   #3
Recently new!
Paulie1138's Avatar
Send a message via AIM to Paulie1138
There is no difference in the antennas. Do not let anybody fool you. Television signals are RF, or radio frequency. You still have UHF and VHF signals that your TV tuner receives.
The difference is that they went from analog type transmission to digital. This allows them to pack in more channels per old type channel. This is where you get your 3.1, 3.2, 3.4, etc. Some sets show it as 3-1, 3-2, you get the idea.
With digital, typical transmissions are a lot clearer. Typically, you either get a signal or you don’t. When on the edge of the signal, you get the freezing and glitchy reception. Typically, you do not get snow anymore, well, maybe ON the antenna....LOL.
Hope this helps. There is more to this, but this is the basics. You do not need a special antenna. If you are far from the stations, then, use a beam type antenna. Most RV’s have them-you have to point it towards the stations. Then again, some work better than others. I added the small clip-on for my “batwing” and it helps a lot to pull in the higher channels.
1987 Starcraft Nova tent trailer, purch. '87, sold 8.14
2013 Crusader 290RLT bought new, 8.14 lotsa mods!
2001 Ford F-250 7.3
Loving wife, R.I.P., 6/6/19
and Mason the always dirty dog! R.I.P, 2/19
Paulie1138 is offline   Reply With Quote
Old 02-24-2019, 02:47 PM   #4
Trailer Park Supervisor
NJKris's Avatar
There is no such thing as an “HD” antenna or “digital” antenna—the format of the signals being received doesn’t matter—and take those “miles” range claims in the product specifications with a grain of salt. No manufacturer can guarantee their antenna will pull in a signal from a given number of miles because too much depends on local topology, signal strength, interference, and other factors unique to your location.
Antennae are generally VHF or UHF, or combination. They are both capable of receiving digital OTA (over the air) signals. VHF channels 2-13, and UHF anything higher.
NJKris is offline   Reply With Quote
Old 02-24-2019, 02:47 PM   #5
NJKris's Avatar
Paulie, you beat me to it, lol.
Old 02-24-2019, 03:01 PM   #6
Yes. This whole HD antenna is a sham. It's all UHF (except the occasional station that gets a variance) now, so the same frequencies as the old 14-83. What's being broadcast is different, but the waves that carry it are the same.
aeblank is online now   Reply With Quote
Old 02-24-2019, 03:08 PM   #7
To all, VHF bands are no longer used for tv. The govt sold those bands for big money. Though some stations got variances to continue using those frequencies (one near me did, that's why I know). HD is broadcast on what used to be the UHF bands.
So while the VHF portion of your antenna will still pull in UHF signal, generally you only need the UHF portion. It's the V looking part of an old long range antenna.
Just saying.....
But again, there is no special antenna for HD.
Old 02-24-2019, 03:08 PM   #8
Read up on it here: https://en.wikipedia.org/wiki/UHF_te...n_broadcasting
Actually, there is a difference. It's not "digital" vs "analog", as the antenna still receives analog signals. "Analog" antennas are designed to receive 2-6 - low VHF, 7-13 - high VHF, and 14-83. At the transition to "digital" (which means the analog carrier is carrying the digital signals) all VHF channels were no longer used to transmit television signals. It wasn't long after the transition for some channels to move back to the high VHF - 7-13 channels.
Therefore, the same antenna that worked before the transition works fine after, except the elements designed to receive 2-6 no longer are used. A current antenna is tuned to receive high VHF and UHF. As most of the channels were on the VHF bands before the transition, most antennas of the day were optimized for those channels. Now that most of the transmission is on the UHF bands, the newer antennas are optimized for these bands.
Pics:
The great converter coupon give away:
Pure UHF antenna: (first stage of the transition)
High VHF/UHF antenna - note the vast majority is the Yagi elements:
As our property is rural, and I refuse to pay someone to receive the same TV I normally watch that is broadcast OTA (Over The Air), I've been over this ground...
To be RV Specific - if you have a unit that is older than about 2008, your antenna is designed for low & high VHF and UHF, but is not optimized for UHF. You can purchase a device that enhances the UHF section. After about that date, the antennas were optimized for high VHF and UHF.
Hope that helps!
2016 2250LE/Chevy
Formerly: 2000 Four Winds 26Q/Ford, '96 Kit Sportsmaster 22' 5th wheel, '91 Sunlite truck camper, Wildernest flip-top canopy
brucemc is offline   Reply With Quote
Old 02-24-2019, 03:56 PM   #9
NJKris's Avatar
I refuse to watch 'TV' period, lol. Cut my cable 3 years ago (well almost, I still get cable internet). Best thing I ever did. For awhile, i did get OTA using a yagi rooftop antenna, but now I don't even bother. If I can't stream it on Netflix or Prime, commercial free, it's not worth watching.
Old 02-24-2019, 04:23 PM   #10
Around here at least, the local channels kept their same numbers from the old days. That was done for brand loyalty I think. But in reality, they are all UHF channels now. The higher the frequency, the shorter the antenna elements are. My unit came with the “Batwing”. I added the “wingman” and it helped bring in a lot more channels BUT it made the antenna a lot more directional. If the OP has a Batwing, he should get the wingman. Just my experience. Jay
Jay2504 is offline   Reply With Quote
antenna, led
