Old 06-28-2015, 02:16 PM   #1
Where is my inside Water Heater Switch?
Just got a new Vengence28v. As I understand it this is supposed to have LP and elec. water heater. I found the outside little black rocker switch to turn the elec part on but there is on/off switch inside to turn the LP function on? Anyone know where it is?
Midlife Cruiser is offline   Reply With Quote
Old 06-28-2015, 02:18 PM   #2
bikendan's Avatar
you should have a rocker switch inside for the PROPANE side of the WH.
most times it's located near the water pump switch and the tank level monitor panel.
the only inside switch for the electrical side, is the breaker assigned to it.
Equalizer WDH
Old 06-28-2015, 02:30 PM   #3
There is a switch marked Htr right next to the Pump switch but they told me that was for the heated holding tanks???
Old 06-28-2015, 02:34 PM   #4
TURBS's Avatar
I think that's for your water heater.
When you turn it on can you hear the burner start?
Make sure wh is full of water first by opening pressure relief valve!
My old flagstaff had tank heaters and the switch said "tank heater"
TURBS
08 duramax tuned n modded
2011 32bhok Sabre
2015 camping "11 nights"
Old 06-28-2015, 02:37 PM   #5
Yup, that did it. Turned that switch on and it fired right up. Thanks guys
heater, water, water heater
