01-07-2017, 02:14 PM
Where is the Furnace exhaust vent?
We have a 2012 Forest River Forester 3011DS. Can anyone tell me where the furnace exhaust is on the outside? On the roof or on the side? Thanks.
01-07-2017, 02:33 PM
Under the fridge you should find the furnace. It should be exhausted through the side just above the right rear tires & under the outside fridge vent.
2014 Prime Time Sanibel 3250
01-07-2017, 02:53 PM
If it is a suburban should look like:
2005 Dodge 3500 Cummins
2017 Wildwood Lodge 4092 BFL
1966 Mustang GT
1986 Mustang SVO
01-07-2017, 03:15 PM
i would purchase a fine mess screen cover from ebay to keep out mud dobbers
01-08-2017, 03:54 PM
Dazed & Confused
Cheap insurance.
Valterra Bug Screens for Suburban and Duo-Therm RV Furnace Vents
~Mike & Kim~
2014 Rockwood Windjammer 3008W Diamond Package
2020 Ram 2500 6.4L Crew cab 4WD, 4.10 Axel
01-08-2017, 05:00 PM
X2, I once had a furnace motor destroyed when the daubers built a nest in the squirrel cage. The imbalance wrecked the bushings on the motor. A $100 fix but Ive had a screen on EVERYTHING since and no further problems.
2009 Chevy Silverado 2500HD CCSB LTZ Diesel, Fumoto Oil Drain Valve, Turbo Brake activated, 39 gal Aux Tank W/ Fuel Pump transfer, Air Lift Loadlifter 5000 air bags.
01-08-2017, 06:02 PM
Turn the heater on. Fan will start for 30 seconds before ignition. That will give you time to go outside and find where the noise and air is coming from.
Douglas, been through Maurice many time. Always get the boudin but don't care for Turduckens. Went to school in Abbeville and have good friends who live between Maurice and Lafayette.
2013 Crusader 330 MKS
2013 Chevrolet Silverado LT 2500 D/A
01-09-2017, 03:18 PM
lost heat?
Outside when my furnace was running, I couldn't believe how much heat was being ejected. Is it working properly? Is there no way to reclaim this heat?
Jean 7752
'98 Toyota T-100
'09 Forest River Rockwood Mini-Lite 1809
Arizona
traveling with Famous Peaches, silver tabby cat, child of the Wild
01-10-2017, 01:59 PM
AKA: 'tiredTeacher
That's exhaust from the furnace's combustion chamber. To recapture the heat you would have to build an exhaust system that re-entered the trailer and gave off the heat through an exposed exhaust pipe acting as a radiator before exiting the trailer. (Ben Franklin did this with his stove.)
Wright and Penny
(with Fitz and Lizzie, the camping kitties)
Richmond, Va.
2010 Tundra 4X4 5.7L V8
2014 Rockwood 2604WS
Life is a cruel teacher. She gives the test first; the lesson then follows.
01-10-2017, 02:26 PM
Ever measured the temps coming out of a home chimney?
Same phenomenon.
02-14-2017, 12:30 AM
Please don't try to reclaim the heat. Any leak would kill you with carbon monoxide.
Kirk
2017 Forester 3051S
