Old 01-07-2017, 02:14 PM   #1
Where is the Furnace exhaust vent?
We have a 2012 Forest River Forester 3011DS. Can anyone tell me where the furnace exhaust is on the outside? On the roof or on the side? Thanks.
blue daze is offline   Reply With Quote
Old 01-07-2017, 02:33 PM   #2
rracer5's Avatar
Under the fridge you should find the furnace. It should be exhausted through the side just above the right rear tires & under the outside fridge vent.
2014 Sanibel 3250
rracer5 is offline   Reply With Quote
Old 01-07-2017, 02:53 PM   #3
Oaklevel's Avatar
If it is a suburban should look like:
2005 Dodge 3500 Cummins
2013 Puma Unleashed 356 QLB
1966 Mustang GT
1986 Mustang SVO
Sadie & Lillie Spoiled Rotten Boxers
Old 01-07-2017, 03:15 PM   #4
i would purchase a fine mess screen cover from ebay to keep out mud dobbers
Gee Whiz is offline   Reply With Quote
Old 01-08-2017, 03:54 PM   #5
Dazed & Confused
M&K Hoffman's Avatar
Cheap insurance.
Valterra Bug Screens for Suburban and Duo-Therm RV Furnace Vents
~Mike & Kim~
2014 Rockwood Windjammer 3008W Diamond Package
2012 Toyota Tundra Doublecab 5.7 4WD
M&K Hoffman is offline   Reply With Quote
Old 01-08-2017, 05:00 PM   #6
DouglasReid's Avatar
X2, I once had a furnace motor destroyed when the daubers built a nest in the squirrel cage. The imbalance wrecked the bushings on the motor. A $100 fix but Ive had a screen on EVERYTHING since and no further problems.
Maurice, LA
2012 Wildcat Sterling 32RL
2008 Chevy Silverado 2500HD LT Diesel
TST TPMS system w/ Flow-thru sensors
2001 Cougar 281 EFS (sold)
DouglasReid is offline   Reply With Quote
Old 01-08-2017, 06:02 PM   #7
Send a message via MSN to Tiggerdad
Turn the heater on. Fan will start for 30 seconds before ignition. That will give you time to go outside and find where the noise and air is coming from.
Douglas, been through Maurice many time. Always get the boudin but don't care for Turduckens. Went to school in Abbeville and have good friends who live between Maurice and Lafayette.
2013 Crusader 330 MKS
2013 Chevrolet Silverado LT 2500 D/A
Tiggerdad is offline   Reply With Quote
Old 01-09-2017, 03:18 PM   #8
lost heat?
Outside when my furnace was running, I couldn't believe how much heat was being ejected. Is it working properly? Is there no way to reclaim this heat?
Jean 7752
'98 Toyota T-100
'09 Forest River Rockwood Mini-Lite 1809
Arizona
traveling with Famous Peaches, silver tabby cat, child of the Wild
Jean 7752 is offline   Reply With Quote
Old 01-10-2017, 01:59 PM   #9
AKA: 'tiredTeacher
awellis3's Avatar
That's exhaust from the furnace's combustion chamber. To recapture the heat you would have to build an exhaust system that re-entered the trailer and gave off the heat through an exposed exhaust pipe acting as a radiator before exiting the trailer. (Ben Franklin did this with his stove.)
Wright and Penny
(with Fitz and Lizzie, the camping kitties)
Richmond, Va.
2010 Tundra 4X4 5.7L V8
2014 Rockwood 2604WS
Life is a cruel teacher. She gives the test first; the lesson then follows.
awellis3 is offline   Reply With Quote
Old 01-10-2017, 02:26 PM   #10
Ever measured the temps coming out of a home chimney?
Same phenomenon.
2016 Flagstaff 8529IKBS Diamond Package 5th Wheel
Ford F-Series SCREW 4x4
TST Tire Monitor - Sinemate 3500w Gen.
2016 Nights Camped = 46
furnace, vent
