Old 08-23-2015, 11:51 AM   #1
Where is the Trailer inverter circuit for charging the battery?
I have a 2009 30' Cherokee Grey Wolf. Left for two day camping trip with a fully charged brand new (1month old) deep cycle battery. Brought along the Yamaha 3000 Watt inverter and run it all day. By evening the lights were dimming and the furnace and fridge were shutting down. The fridge was on propane by the way. I recognized it to e a dieing battery so I tried my smart deep cycle battery charger plugged into the Yamaha. It would not take a charge. All the lights flashed like it was a defective battery. Hooked up the truck with jumper cables and not much improvement. The lights on the microwave were even dim but would work if used. So generator was producing. My question is, where is the circuit in the on board trailer inverter that should be charging the battery when the Yamaha is running and plugged into the trailer. Seems to me it must not be feeding any juice to the battery at all.
I left the truck battery hooked up all night and restarted the yamaha in the morning. Reconnected the smart charger and the deep cycle battery is now charging fine. Very frustrating trailer all around.
ID:	86603   Click image for larger version
aullie70 is offline   Reply With Quote
Old 08-23-2015, 03:38 PM   #2
Head Rambler
Are you getting power from the battery when not hooked to A/C power or an outside battery (truck)?
If no, then it could be a blown fuse or fuses. I'd check all the fuses even if they don't look blown.
Gotta go campin!
Old 08-23-2015, 03:47 PM   #3
I am getting juice from the battery when I recharged it. I found the manual for the inverter and it says I should be getting 13.6V from the battery leads on the inverter in the trailer when connected to shore power or the yamaha in this case I presume. I'm buying a multi tester as I type this to check that out. I looked at the fuses and they appear good.
Old 08-23-2015, 03:54 PM   #4
bikendan's Avatar
Just to clarify, you're talking about a CONVERTER, not an INverter.
Equalizer WDH
Old 08-23-2015, 04:17 PM   #5
The yamaha is an inverter generator 3000 Watt. EF3000I I believe. The electrical panel in the trailer I thought was also called an inverter but I could be wrong
Old 08-23-2015, 04:55 PM   #6
bikendan's Avatar
no, you have a WFCO CONverter as your pic label states.
it converts 110v AC to 12v DC.
an inverter does the opposite, 12v DC to 110v AC.
Equalizer WDH
Old 08-23-2015, 04:58 PM   #7
Thanks for the clarification, I've learned a lot on this forum
Old 08-23-2015, 05:07 PM   #8
Ok, let's see if I can help. If you read your own pictures you'll see that it says converter right on the unit. A converter converts 120v AC into 12v DC power.
An Inverter does just the opposite. 12v DC into 120V AC. Just google inverter generator for an explanation of why it is an inverter generator instead of a regular generator.
Check for blown reverse polarity fuses, the 40w orange ones you see in the fuse panel. Did you accidently hook up or even touch the cables to the wrong terminals on the battery when you changed it? One second of reverse polarity will blow those fuses. Then the converter won't work.
To locate the Converter in your RV just take that whole front panel off the unit
and you will see the "converter" underneath the distribution panel portion of the power unit. There's usually a tin panel in front of it to protect it. Open the flip down door and there's 2 screws near the top (I can see 2 chrome screw heads in your picture)and tip the top front down to remove the panel. Voila' there's the converter supplying 12v power to the distribution panel and hopefully sending a charge to the battery. Be careful when doing this as you are exposing 120v breakers and wiring that's dangerous. Don't touch anything in there if you don't know what you're doing.
WFCO converters a not a high quality unit and it's possible the converter/charger section has gone bad. If so they can be easily replaced with better quality converter/charger units. Go to BestConverter - Converters, Inverters, Electrical Supplies, Electronics to find replacements.
you can check out this webpage to see what I'm talking about. It shows you how to trouble shoot the converter. Specifically page 7 of the manual. https://www.rexandsonsrvs.com/manual...ter_Manual.pdf
Semi retired now and enjoying it.
2013 F150 Super Cab 4x4, 3.5L ecoboost , 7700lb suspension package. 11,300 towing capacity and Max Tow package
2015 Flagstaff 8528IKWS Diamond
aquaholic3 is offline   Reply With Quote
Old 08-23-2015, 05:11 PM   #9
Sorry, the link to the manual wasn't complete in my first post. This is the manual for Similar WFCO converter units and should help identify things
Old 08-23-2015, 05:18 PM   #10
Thanks again, I'll definitely check it out. I see some of the 12V text in your reply. I read that info and it was somewhat helpful. I am almost positive I didn't reverse the leads but will check the fuses again with my meter. I have some reading to do I guess. Thanks for your posts everyone. I'll update once I figure this out.
battery, charging, inverter, trailer
