Old 09-30-2016, 08:51 PM   #1
Whirlpool refrigerator
I have a 2016 forest river vibe 268rks with a whirl pool refrigerator.
We where told it will run off of 12v but it isn't working.
only when the trailer is pluged in to 120v that it turns on.
Should it be working on 12volts in dry camping or while towing?
Navaner is offline   Reply With Quote
Old 09-30-2016, 09:05 PM   #2
I have four 6 volt batteries in mine, and my refrigerator will work 4 days on battery power. Is your batteries good.
2015 Cedar Creek 32RL
2012 Silverado 3500HD SRW
http://www.forestriverforums.com/for...ignhavefun.gif
spock123 is offline   Reply With Quote
Old 09-30-2016, 11:41 PM   #3
I have 2 massive deep cycle batteries.
My fridge is not a propane or electric.
It is stricly electric 110v
Old 09-30-2016, 11:44 PM   #4
My batterries are 3 days old. And power the rest of the rv with no issues
Big Dawg
2015 Titan pro 4 x
Old 10-01-2016, 08:36 AM   #5
The batteries are probably not wired right. When I first got my camper everything would work in the camper but the refrigerator, it turns out the batteries were not wired correctly
Old 10-01-2016, 08:39 AM   #6
Have you checked your inverter? You have a inverter just to run the refrigerator. My inverter is a 1,000 watts and it has to be on, it just powers the refrigerator
Old 10-01-2016, 09:34 AM   #7
Agreed, make sure that your inverter is turned on (on my coach it is a small black switch by the steps that glows green when it is running.
It is also possible that you have the same kind of inverter that I do and the GFI outlet on the back of the unit is popped. Standard household GFI, just push the reset button.
2015 335DS
ScottBrownstein is offline   Reply With Quote
Old 10-01-2016, 10:14 AM   #8
The inverter works only when the trailer is pluged in to 110v.
The inverter i have seems to cobvert 110v to 12v.and charge my batteries when pluged in tob110v.
Unless it's a dual inverter.
Il go check the gfi just in case and my batterries
Old 10-01-2016, 11:26 AM   #9
What you are talking about is the converter, there is a difference, the inverter does not charge the batteries. The inverter just powers the refrigerator when not hooked up to shore power, like running down the road
Old 10-01-2016, 11:32 AM   #10
No I am talking abouts the inverter.
It clearly says on it it's the inverter
refrigerator
