06-23-2015, 05:29 PM
Why does my A/C not cool the camper?!
The unit seems to be functioning, just doesn't cool the camper down as much as I think it should. It's a 15K unit and the air coming out is cold, but doesn't seem to be blowing hard enough out of the vents in relation to how loud the fan is blowing. I know it won't be freezing inside, but it should get cooler than 89 during the day. Current outside temp is 97 according to the weather channel.
2015 Surveyor Cadet 294 QBLE
06-23-2015, 08:40 PM
Could be construction debris in the tubes going to the vents.
06-23-2015, 08:46 PM
Mine is two years old and it spits out styrofoam giblets every time I turn it on. Heater too. Snow in summer!!
Aviator Wright Flyer #1919
Army Pathfinder Vietnam, 3 tours
DAV, MOPH, VFW, NRA, 1stCav. ABN
06-23-2015, 08:48 PM
My friend had the same problem with his 15,000 BTU. Follow this link to see how he solved his problem. Needed a new AC unit.
http://www.forestriverforums.com/for...ure-83163.html
Bill & Cindy McKenna
Philadelphia PA
2015 Palomino Puma 32DBKS
2005 Ford Excursion 6 liter Turbo Diesel
06-23-2015, 08:58 PM
Couple of things to add here / Are you camping under shade or under direct sun? 97 degrees under a hot bright sun could be well over 115 plus on the rv. My single a/c in my unit is not enough for camping in direct sun on super hot days. 10 degree drop could be the best under those conditions.
When the unit is hot I like to open the vents on the a/c unit itself to get a cold blast in the camper in one area.. May even open the roof vents just for a bit when doing the first cool down to help shove the hot air out..
10 to 12 degrees cooler is about all I can get in the sun on hot days if I remember right.
2014 LaCrosse 323RST-TE-C
2009 Chevy 2500HD Z71
Seasonal
Zelda the campin dog
06-23-2015, 09:14 PM
I'm in direct sunlight until about 6 pm. Not many trees in this part of AZ. I think it's just too hot. I measured the air at the intake with a digital meat thermometer and it was 81.4. Air temp out of the vents was 47.8.
06-23-2015, 09:28 PM
Sounds like an air flow issue. Your exhaust is quite cold already.
I would make sure the duct work is clear and unobstructed.
On my new 5er, I had to remove the vents and retape the ductwork to the openings properly because it had been poorly done at the factory. There were many openings that caused the cooled air to vent into the attic which reduced the efficiency greatly. When I finished the fix, it helped a lot.
2020 SOB - Jayco North Point 387RDFS
2013 Crusader 325RES Touring Edition - SOLD
TV: 2018 GMC Sierra Denali HD CC SRW L5P Duramax Curt Q20
06-23-2015, 09:45 PM
I'll try that tomorrow. Thanks for the tips!
06-23-2015, 09:57 PM
One other area you might look into is ensuring all air spaces are tightly sealed. You can take on a lot of heated air around pipes or wires coming up from a sealed underbelly or basement. They can act like an oven superheating the air and forcing it up into your living space.
Using a vent pillow or similar in your vent openings will help reduce heat, as well as blocking out any skylights. Light colored fabric curtains over your windows (vs. mini-blinds) will also help.
06-23-2015, 10:16 PM
Ret E-9 Anchor-clanker
I think you have a 33 footer? That a lot of space to cool so your going to have issues to deal with. Is your AC in the rear? Then close off the front when your not in there. That goes for the bathrooms too. Do you have a sky light in the bath area? Cover it (I use a combo thermal pillow). All of your vets need outside covers and inside pillows (screw handles removed). Small fans help circulate air. Does your AC have local diffusers? And, ducted vents? After you have cleaned the screen/filter and after you have verified the vented/ducted passage ways, try this. During the day open the AC diffusers, at night keep them closed. Also the stove exhaust fan has a flapper door that needs to be clipped closed when not I use. Finally, buy a heat sensor gun. It will help you find hot spots to deal with and it also will tell you the cool spots during the cold days. I read here someone was going to install an additional AC on the forward vent. We haven't heard from him (or I missed it). His RV was a 30amp unit so he was also installing an electrical outlet that would plug directly into the 20amp outlet on the power pole. Cover under trees play an important role for shade. Let us know how things are working for you.
06-24-2015, 12:02 PM
As a fellow Arizonan, in June, in the sun, 97 degrees out, it's doing all it can. Pull the shades, better yet block the windows, but that's all you're going to get. Maybe block off part of your unit?
06-24-2015, 12:20 PM
When it's 97 degrees outside and high humidity, run your fan on high, not auto. The fan will run constantly, the compressor will come on as needed. In the evening, turn the fan to auto so it will come on as needed. the A/C will be a lot more efficient and cool better.
Tom
06-24-2015, 12:23 PM
Tom
Just checked the humidity where I'm at in AZ and its 12%
06-24-2015, 12:25 PM
Most of the time I run a cool mist humidifier 24 hours a day when camping to get the humidity into the mid 30s at best
06-24-2015, 12:29 PM
I'm not sure I understand why your using a humidifier and not a dehumidifier?
Am I missing something?
Humidifier = winter
Dehumidifier = summer
Never mind.......
I thought you were in a humid location.
TURBS
08 duramax tuned n modded
2011 32bhok Sabre
2015 camping "11 nights"
06-24-2015, 12:31 PM
Arizona is a very dry desert. The rules from areas back east or up north don't apply. The humidity rarely gets above 20% no matter the season. This time of year it's below 10% much of the time. Low humidity is tough on your sinuses and cracks your woodwork.
06-24-2015, 12:41 PM
You are lucky. I'm in Alabama. The temperature is supposed to get to 99 degrees today with a humidity of 42%.
06-24-2015, 12:43 PM
Here you can get out of a pool in 105 degree weather and shiver because of the extreme evaporation
06-24-2015, 12:50 PM
Utah Kid
Second air may help
I have a second air for the trailer, a 15 and a 13. I use it in hot S. Utah. Works just fine. Also use a small fan to circulate the air in the area I'm in. You might want to keep your shades down during the hot times of the day also.
Good luck!
RC
06-24-2015, 12:52 PM
Occasional campers
Evaporative coolers are common and effective indry climates. In humid locations like Alabama they're less than useless!
