Old 11-07-2017, 04:40 PM   #11
SlfMdeFam's Avatar
Originally Posted by BamaBob View Post
You need to call Forest River. A WiFi Ranger antenna without a router is non-functional. It will pull a signal in, yes, but without a router there is no way to broadcast that signal in your RV
That makes complete sense. Thanks for that advice.
SlfMdeFam is offline   Reply With Quote
Old 11-07-2017, 05:07 PM   #12
Cypressloser's Avatar
Location: Alberta - East of the Rockies, West of the Rest
When you scan for wifi connections on your phone, tablet or computer do you see the wifi ranger? If you do you need to connect to it using the password provided, then enter the following numbers in the browser window address bar 10.113.23.1:8080, this should open the control panel window for the WIFI Ranger from where you can configure your connections. The actual router, the piece that is mounted inside the rv can be hidden somewhere out of sight, it is not necessary to connect a computer via cable to do the setup.
The Wifi Ranger website has very detailed instructions and tutorials.
Name:	Screenshot-2017-11-7 811323 Control Panel.jpg
2018 RAM 5500 Laramie CC
Riverstone Legacy 38RE, 960 Watt Solar, 6x6 Volt AGM Battery Bank, Freedom SW 3012 Inv/Charger
Cypressloser is offline   Reply With Quote
Old 11-07-2017, 05:12 PM   #13
SlfMdeFam's Avatar
Ok so i did all that correctly. But it still wouldnít let me connect. It was saying it wasnít connected to the parks WiFi. Something along the lines of the parks WiFi was filtering or something like that. Iíll be back out in the Rv in a couple weeks so Iíll give it another shot.
Once again, many thanks.
