Old 05-07-2012, 04:34 PM   #1
wildcat 31thsb tv coax wiring diagram
I am trying to hook up a dish network hd sattelite. Need a wiring diagram to see how its all set up. Hooked up the sattelite to the the cable in on the outside, then reciever to the outlets above the fridge,but get no signal to the tv......any advice???????
chipnkim is offline   Reply With Quote
Old 05-07-2012, 05:34 PM   #2
TURBS's Avatar
no wiring diagram available . sorry .
but I just hooked up mine last night .
hooked sat outside to the coax connecter labeled "sat" on side of trailer .
inside theres another wall plate with "sat/aux" hooked another coax to that and ran it to the dish reciever .
turned tv to aux 1 or whatever port you hook to . i use red white and yellow rca's and turned on dvr .
when You get dish network on the tv then you have to go to setup and aim sat .
Ron
IF you need help let me know !
Old 05-07-2012, 05:39 PM   #3
TURBS's Avatar
I use a compass app on my android phone and set it at 210 degrees se. I line the leveled dish up by the lnb with my phone parallel with the arm and had signal in 30 seconds .
