Old 08-17-2013, 09:54 AM   #1
Windjammer Cable
Hi all,
I've searched for and read all the threads related to getting park cable working. Our antenna amp (green light button) is OFF. Coax cable is attached from hook-up to the left "cable" jack on outside of TT. Coax cable from TV to Winegard plate is plugged into the "TV" jack (not the "AUX/SAT" one).
Turn on the TV, searched thru the menu. It's still looking for analog channels on the channel scan, even though I've put every option I can on "cable".
I'm pretty sure it's some setting on the TV that I'm not figuring out. Any help would be great!
Thanks, Sissy
sissyandbob is offline   Reply With Quote
Old 08-17-2013, 10:05 AM   #2
It's going to search for both analog and digital stations. Maybe it does the analog first.
I would try plugging the park cable into the Sat jack on the outside of your RV. It's not uncommon for them to reverse those two cables when they build the RV.
windjammer
