Old 06-26-2014, 11:27 AM   #1
JimnSylvia's Avatar
Window A/C versus Roof A/C
Really, which is cheaper to run? We are thinking that our direct vent roof unit might be ridiculously expensive. We can also run it through ducted outlets.
I don't know the btus on it.
What would be the amount of btus to use in a 240 sf room?
Do you advice a window unit?
Your help greatly appreciated!
Thanks,
Sylvia
2001 Forest River Cedar Creek 5th Wheel
Full-Timers in a permanent location since 6/12
JimnSylvia is offline   Reply With Quote
Old 06-26-2014, 12:55 PM   #2
VinceU's Avatar
Your profile indicates you 're in a perm site. Best bet may be a "split Pak" where a fan driven cooling, 2' bar is mounted inside wall. Outside mount compressor etc and join the two via wire and tubing. Outside looks like miniature a/c unit. Very efficient and reliable. I think made by Samsung and Sanyo. Saw one the other day in an old trailer. Rated for 1 Ton, plenty for your space. Requires 1 1/2" hole compared to 14" in roof and more in wall.
Old 06-26-2014, 01:38 PM   #3
bend302's Avatar
They are called "split" units. Saw them all over Asia in the early 90's. Don't know why it took so long to get them into the US.
They have heat pump ones that will heat as well.
Bill
Life is a journey, not a destination.
2005 Georgetown 359ts
Bill & Virginia, Kentucky
Nights camped in 2011...78 , 2012...73,
Nights camped in 2013...123, 2014 ...101
bend302 is offline   Reply With Quote
roo, roof
