Old 12-26-2019, 05:09 PM   #1
Winegard Rayzar.z1 no reception on 528RKS
My Winegard RAYZAR.z1 was working fine and picking up several over the air stations at my home location and worked fine at my last camping spot. However after last trip, now can not get any stations when doing scans on either TV at home location. All cables that I can easily see are secure, and the green light is on indicating that it is set up for antenna. I am concerned that something may have vibrated loose during my return home. Any experience on how to test that cable is still hooked to antenna, without opening it up on the top?
rpowers99 is offline   Reply With Quote
Old 12-30-2019, 10:29 AM   #2
SeaDog's Avatar
My advice before going to any extremes is double check and make sure your TV set is set to antenna and redo the scan.
Retired Navy
Jake my sidekick (yellow Lab)
2016 Flagstaff 26 FKWS
Old 12-30-2019, 11:13 AM   #3
It is possible that there isn't much there. Check with this:
https://www.disablemycable.com/station-finder/
john221us is offline   Reply With Quote
reception
