Old 05-13-2013, 08:17 PM   #1
PHS79's Avatar
Winegard Road Star 1500 antenna
We have the Winegard RS 1500 on our Grey Wolf, the problem is that we can't get very many stations in. Our friends may be able to get 6-7 stations and we are only able to get 2,3 maybe 4 channels of those only about 1/2 will actually stay on without freezing up and cutting out. This is with the booster turned on.
Are there any upgrades, like another booster or something, available for the Winegard 1500? Or is there direct, bolt on, replacement for the 1500 available? If neither of those what would be our best route to go?
Thanks!
TT-2013 Passport 3220BH
TV-2004 F150 FX4, not exactly stock...
nights camped:
with 2001 Kodiak K215: 2010-10, 2011-12
with 2012 Grey Wolf 26BH: 2012-19, 2013-24, 2014-11, 2015-6
with 2013 Passport: 2015-13, 2016-15 booked
PHS79 is offline   Reply With Quote
Old 05-13-2013, 09:51 PM   #2
jtstromsburg's Avatar
When we had our grey wolf, we found similar results. I did find a lose connection under the tv and tightening it helped. I was looking into changing to a Jack antenna, but then the dw decided she wanted a fifth wheel...
Not sure much can be done other then changing the whole antenna out (unless there are loose connections in the coax)
Joel and Teresa
2016 Sabre 34TBOK
2006 GMC 3500 CC LB DRW 4X4
jtstromsburg is online now   Reply With Quote
Old 05-14-2013, 08:03 AM   #3
WestCoastRV'er's Avatar
I just replaced mine with JackTV and went from 12 stations to 17 stations. Took all of 5 minutes to unpack and replace the head unit. Very easy task.
2011 2902ss Rockwood Ultralight
2008 Grand Cherokee 3.0L Diesel (255 hp @ 2900 rpm / 430 lb-ft @ 1,400-2,800 rpm)
3P ProPride Hitch
RV Mods
Wandering RV Life
WestCoastRV'er is offline   Reply With Quote
Old 09-02-2013, 08:46 PM   #4
Our Grey Wolf has the same problem. Very few channels and my wife's parents can be setup in their camper one spot over and get lots more channels and wife's sister and her husband can be on the other side and their camper gets more channels too. They both have the crank up style antenna so I've wondered if that might be making a difference but I've also heard the built in tuner in the off brand tv that came with our camper really sucks so I've been meaning to take along another tv from our house that is a name brand to compare and see if that makes a difference.
2004 Ford Expedition
2012 Cherokee Grey Wolf 28BH
2001 Rockwood Freedom 2280 popup <--For Sale
JTHale13 is offline   Reply With Quote
