Wiring in a television to 12 volts need some info
The previous owner decided to take the television out of the travel trailer we just bought. I purchased an LCD TV and two things that I thought would work out well on this model is very low power consumption 30 watts and the tv works off of 12 volts. The plug for the 120 AC to plug it in at home has 100-240 volts input and output is 12 volts and 3 amps. I'm wondering if I can power this TV if I run it off the 12 volts that supplied power to the original tv? I found out the TV takes an "N" barrel connector I could buy at radio shack but the sales guy told me I should not exceed the 3 amps the wall adapter puts out. I see in the travel trailers panel the fuse marked for entertainment center has a 15 amp fuse. Will this damage the TV? I'm not real witty when it comes to stuff like this so any help would be appreciated.
2013 Wildcat 323QB
08 Silverado Crew Cab 2500HD Duramax-Allison
Twin Honda 2000 campsite friendly generators
Nights camped in 2014 = 19
(2013 = 36)
(2012 = 42)
