OK everyone, I found the the wiring path for the +/- lines on the Awning LED. the power feed (+/-) comes down from the LED strip in the Front Awning Leg. It is behind a black cover, but it enters the camper behind the dresser. I removed the bottom drawers and there it was. I promptly changes colors and I believe it goes in the the front Secondary battery location (small door in front of the large storage area on the camper door side. Now that I know where the wire goes, I am changing my plan. Here is what I am going to do:
I ordered a new dimmer switch like this
DC 12V 24V LED Dimmer Single Color Adjust Power Supply for LED Light Strip US | eBay
and I am going to locate it in the Battery Bay. This will fix a couple problems:
1. I really do not need another remote in the camper
2. With the controller that requires a remote, it will be complicated. If you want the awning light on, you would need to flip the switch on the control panel, or use the LINC remote to send power, then you would have to use the LED remote to actually turn on the light. This would be a pain.
3. Whenever the awning light is on I will be able to adjust it without going on the hunt for a remote.
The only drawback is that the remote controller can vary the lights in patterns etc. May or may not be important to you.
When my new dimmer arrives, I will try and take pictures as I install it for the group.
Robb
