Old 02-26-2019, 07:15 PM   #1
Good Ole Dad
G.O.D.'s Avatar
WooHoo Got Heat
I have been working on a Suburban 30 that Quit giving Heat the last week of Dec.
Read all of the Post and decided it was the Card. Good Ole Amazon had a Card and a Flow switch. Changed em both. Installed the Heater aaaand it didn't work, Darn darndarndarn. I should not have Sealed the Exhaust intake Ports. At least I did not put the Couch back together. Take it back out , put on the table take it out of the Case and I find a Switch that I knew was there but did not look at when I installed the First time in, THE OFF Position. Friken Gremilins, I know it wasn't my Fault. Flipped the Switch to On Reinstalled and it works. I did Install Quick Disconnects on the Wiring and Arranged the Gas for Easier Access.
For those of You that are Handy it was 4 Wires 12 Various Screws and a Gas Line, to Remove the Heater. To Replace the Card you remove the Heater from it's Box. If you need Help Message Me. Yes Got Heat.
2016 F150 Super Crew 4x4
V6 3.5 Turbo, Auto 6 Speed, Axle=3.55
Rear Air Shocks. Ride Rite. 10 PSI.
Hensley Arrow.
2021 262RL StarCraft.
G.O.D. is offline   Reply With Quote
Old 02-26-2019, 08:21 PM   #2
A32Deuce's Avatar
Glad to hear that!
A32Deuce is offline   Reply With Quote
