Old 10-06-2011, 05:06 PM   #1
JEFF BARTON's Avatar
Xm radio no signal
The xm radio works in the house but says no signal when in the cradle in my rockwood 8313ss
JEFF BARTON is offline   Reply With Quote
Old 10-06-2011, 05:20 PM   #2
Where is the antenna located? Is the coax in good shape with no kinks or cuts? Does the antenna have a clear view of the sky? the the antenna connector in good shape? Satellite antennas are active (circuitry in the antenna), coax has to be un damaged. Satellite signals are very low power, that is why the antenna must have a clear view of the sky and the coax also un damaged and no kinks,
Kirk, KN1B
2013 Cardinal 3800FL
2009 GMC 3500HD CC LB SRW
kbrown1075 is offline   Reply With Quote
Old 10-06-2011, 05:26 PM   #3
The antenna is on the roof which is built in by the factory. There are no trees in sight.
Old 10-06-2011, 08:09 PM   #4
Lottery Non-Winner
Ovair's Avatar
My guess is there is an "open" in the antenna lead. Might be right at the cradle/dock, but could be a pinch or break anywhere along the length all the way to the "puck". Look for a loose end, or a damaged spot.
2011 Georgetown 337
2009 HD FLHTCU
2007 HD FXSTC
Ovair is offline   Reply With Quote
