Old 05-21-2014, 03:05 PM   #1
tdeal823's Avatar
ZX 700 Radio/DVD player not turning on?
Red power light is slightly light. But nothing works?
Any ideas?
And can I remove the bezel? Looks like it just pulls off but I don't want to break anything.
Tony
Sent from my SCH-I545 using Forest River Forums mobile app
2008 Silverado 2500HD DMax LTZ cc sb 4x4 EFILive tuned, Blocked, Deleted, Rerouted and removed B&W Turnover ball and 5th Companion or Pullrite 24K, riderite 5000 airbags
2011 Sabre 32BHOK-6 most of the options
tdeal823 is offline   Reply With Quote
Old 05-21-2014, 03:34 PM   #2
Owner - RVtronics
Bob Fields's Avatar
Send a message via AIM to Bob Fields Send a message via Skype™ to Bob Fields
First double check all your grounds especially at the battery and converter. Then disconnect the power from the ZX700 completely for 1 minute (red light should be off completely. Then try again.
The easiest thing is to pull the fuse on the back of the zx700.
Pull the trim bezel off and remove mounting screws.
Bob Fields
bob@rvtronics.com
www.rvtronics.com
(781) 281-9440
Bob Fields is offline   Reply With Quote
Old 05-21-2014, 03:41 PM   #3
tdeal823's Avatar
Ok makes sense. I just replaced the battery. I will give it a try.
dvd, radio
