Old 05-08-2011, 03:14 PM   #1
Surveyor Sam's Avatar
ZX50 Faceplate removal and Hum Troubleshooting
Hi, I'm a new user and a new owner of a used 2010 FR Surveyor. I've noticed a hum coming from my ZX50 and I want to pull it out to check the power connections. I want to ask HOW before I try to pull anything.
I noticed yesterday when I was on DC power only that the hum wasn't as loud. I need to check this when I'm on AC again.
Another problem - this unit has A and B speakers inside, and C speakers outside. When the hum is present, it's present on all speakers. That really makes it unusable as the hum is so loud it would disturb my neighbors.
Once someone can give me guidance on removing the faceplate, I'll clean and tighten the connections, including ground. I have a can of Deoxit cleaner for the connections.
I appreciate anyone's help,
Sam
Surveyor Sam is offline   Reply With Quote
Old 05-08-2011, 03:20 PM   #2
sherdep's Avatar
if it is any thing like the ZX75 - look to both sides and you will see two small holes per side - with a small flat head screw driver you litely push in the hole and pull on the side panel towards you and it will pull real easy too.
once you get the two side panels off you will see the (6) six screw holes - probably only using (2) two per side instead of (3) three
2011 Rockwood Mini Lite 2306 - Matt
2004 Dodge Ram 1500 Qaud Cab 4x4 with 35" tires and 3.92 gears, Dynatech Longtube Headers & Fabtech 6" lift + Superchips with shift Tuning
Nights Camped 2011 (37) - 2012 (16)-2013 (2) -2014 (5) -2015(0)
USMC 91 - 95 - F/A-18 Aviation Ordnance
sherdep is offline   Reply With Quote
Old 05-08-2011, 06:04 PM   #3
The ZX50 must be a little different. There are two panels, one on each side, but no holes.
Old 05-08-2011, 06:05 PM   #4
sherdep's Avatar
the holes are small and close to the wood it is mounted against - look from the side and you will see the small holes I am talking about.
I am almost pretty sure the ZX50 is mounted the same way as my ZX75
Old 05-09-2011, 03:48 PM   #5
Thanks. I'll check the sides and let everyone know what I find.
[*]2010 Forest River Surveyor SV-230[*]26 nights in '11, 32 nights in '12, 30 nights in '13[*]30 nights in '13, 38 nights in '14, 32 nights in '15
Old 05-27-2011, 12:17 AM   #6
Finally got the faceplate off about a week ago and checked the connections. Everything appeared to be ok. Today I got the trailer attached to AC and the hum is back. While searching this site, I found several people say the two parts from Radio Shack fix the problem. Snap Choke Core part # 273-0069 & one for the antenna coax called Ferrite Data-Line part # 273-0105. I'll try that soon, but for $6 in parts, Forest River could have solved a lot of radio noise complaints.
Old 05-27-2011, 07:12 AM   #7
acadianbob's Avatar
Our ZX50 hummed mercilessly no matter what I tried. I replaced it with a Jensen unit made for RVs. Hum is gone and much better clarity.
Jensen AWM970 Installed, Pictures
2018 F250 Lariat 6.2 4X4 w 4.30s, 2018 Wildcat 29RLX
2003 Yamaha FJR1300, Demco Premiere Slider
Red Green coffee mugs
Old 05-31-2011, 11:37 AM   #8
I install the parts I listed above and the hum is gone.
