Old 07-31-2011, 07:55 PM   #1
bush's Avatar
zx700 no power
i have the zx700 (concertone i guess. i cant find a brand name on the unit anywhere or in the paper work. i guess they dont want there name on it if its not going to work longer than 2 months) in my camper and its not getting power. i checked the fuse but its good. what else can i check. and how does this thing come apart/out of the camper.
it looks like the power button is lit up but it will not do anything. going on vac this weekend and would like to get this thing working.
bush is offline   Reply With Quote
Old 07-31-2011, 09:54 PM   #2
bush's Avatar
got the cover off and got the unit out. what a cluster of wires!!! dont have a clue what wire is the power and did not want to take any tape loose to check the wires but i did take the fuse out of the back of the unit and check it. it looked good but i replaced it anyways and still nothing.
2011 puma unleashed 298fqu toyhauler.
hauling a 2012 polaris RZRS
pulled by a 2006 chevy 3500 drw 4x4 duramax lbz
Old 07-31-2011, 11:59 PM   #3
Push the zx700 button on your remote once and see what happens. Wayne
wayne anthony is offline   Reply With Quote
Old 08-01-2011, 12:13 AM   #4
bush's Avatar
tried that. thanks
any other ideas??
Old 08-01-2011, 01:54 AM   #5
Pull the fuse in the fuse box and put it back in this will cause it to reboot
2008 8296SS Rockwood Signature Ultralite
2002 Silverado 2500HD extended cab
chevy02 is offline   Reply With Quote
Old 08-01-2011, 02:10 AM   #6
bush's Avatar
i pulled the fuse in the fuse box and the one behind the unit with no luck.
Old 08-01-2011, 06:03 AM   #7
Herk7769's Avatar
Originally Posted by bush View Post
tried that. thanks any other ideas??
Is the unit still under warranty?
I would call the dealer and ask for a new unit.
If not, call their Tech Support.
HAM CALLSIGN - KC3FFW
Old 08-01-2011, 10:26 AM   #8
bush's Avatar
yes its still under waranty but was hoping to get it working before this weekend. plus the dealer is over 2hrs away.
Old 08-01-2011, 03:16 PM   #9
bush's Avatar
called tech support and no answer. said to leave message and they would call back. that was around 1230 and not it 1615 and still no call back.
Old 08-01-2011, 04:41 PM   #10
TAPE? The connections are taped???!!!! If I were you, I would get some quality barrell butt connectors and cut the wire back past the tape residue, restrip them and put them in good butt connectors. If you know how to solder, that would be even better. After you get them put together correctly, test and if working, wire tie the wires so there is no stress on the connectors.
Kirk, KN1B
2013 Cardinal 3800FL
2009 GMC 3500HD CC LB SRW
kbrown1075 is offline   Reply With Quote
