Old 05-11-2015, 11:02 PM   #1
Canadian Member
ZX700 Not Playing Main Voice Track
We have a Concertone ZX700 in our NTU 2011 Rockwood 8293SS. We did our first camping weekend with it this past weekend and everything seems to work great except the DVD player would not play the main voice track on a couple newer DVDs. You could hear the background music and background sounds but not the actors' voices. The 2 DVDs that it had this problem with were from a brand new DVD and Blu-Ray set (one DVD and one Blu-Ray disc). We tried an older DVD and it played that one fine.
The new DVDs play fine at home (on a Blu-Ray player).
Does anybody know if the older Concertones have a firmware/software issue that might prevent it from playing a track on newer DVDs? I tried switching settings from NTSC to PAL and Auto and it didn't make any difference.
2019 Rockwood Signature 8290BS
Old 05-13-2015, 08:10 PM   #2
Canadian Member
Bump.
Old 05-13-2015, 11:05 PM   #3
Fulltime family RVer
I had a very similar issue with my camper- it turns out, the center channel speakers weren't hooked up. Some DVDs played fine because they didn't use surround sound.
It might be worth pulling it out and checking the wires in the back.
Old 05-14-2015, 06:02 AM   #4
Canadian Member
Thanks, ependydad. I'll pull it this weekend and have a look.
Old 05-14-2015, 06:08 AM   #5
B and B's Avatar
X2 Try switching surround off and use stereo as well, if the unit can do this.
B and B is online now   Reply With Quote
Old 05-14-2015, 06:15 AM   #6
rsdata's Avatar
my stereo/DVD unit only played one track of a CD... the left side of the stereo output wires from the back of the unit was not even hooked up... both internal wall speakers played the right side only... easy fix once I figured out how to get the player out of the wall
Too much of anything is bad, but too much good whiskey is barely enough. Mark Twain
2014 Shamrock 183
rsdata is online now   Reply With Quote
Old 05-16-2015, 09:40 PM   #7
Canadian Member
I pulled the ZX-700 this afternoon after finishing up some mods. The unit is mounted in a small upper cabinet just below the ceiling. What a nest of wires! Unfortunately, I didn't have a step stool to stand on so I couldn't tell if the centre channel wires were connected. I'll go back out to the farm (where it's stored) tomorrow with a step stool to try to see if the center channel wires are hooked up properly.
I checked the manual and "Room A" which is the living room, uses 5.1 surround sound. The other 2 "rooms" (the bedroom and outside speakers) are regular stereo.
If I can't tell whether or not the center channels wires are properly connected, I see if I can switch Room A to regular stereo using the on screen settings.
Old 05-18-2015, 10:56 PM   #8
I am having the same issue with the genesis 3.0. How do I turn off the surround?! I didn't get a remote with mine.
Jaimie is offline   Reply With Quote
Old 05-24-2015, 09:29 PM   #9
Canadian Member
Took the camper out this weekend and I was able to get the ZX700 system switched from 5.1 Dolby to VSS (Virtual Surround Sound) in the audio settings. That worked and we could hear the main voice track properly.
Old 05-25-2015, 01:07 AM   #10
But could you hear it out of the center channel speakers? That was our issue and why some things worked and others didn't.
