Old 04-18-2010, 03:30 PM   #1
ZX700 Will Not Power Up!!!
I just took my 2010 Puma 31BHSS out of storage today and my ZX700 will not power up...No power what so ever!!!It worked fine when I put it in storage last fall..Is there a fuse somewhere that I could check?Any suggestions on how I can fix this problem would be most welcome!!!Thank You..
gucci is offline   Reply With Quote
Old 04-19-2010, 03:24 PM   #2
fivecodys's Avatar
That is exactly what happened to mine. There was an in-line fuse behind the unit on mine but it was fine. Real rat's nest back there but you can trace it from the back of the unit.
These units are complete junk! (Sorry I'm not quite over it yet)
Is everything else 12V working?
Bill
2009 Flagstaff 8528 RKSS
2007 Toyota Tundra DC 5.7L V8
Pullrite Superglide 14K
Air Lift 5000
Prodigy Brake Controller
"I've got a mind like a steele.. a......a steele......um.....uh...... what's that thing called again?
fivecodys is offline   Reply With Quote
Old 04-19-2010, 04:16 PM   #3
So did you get it to work after or did you have to replace the unit.I am going to go and see if I can find that fuse....
Old 04-19-2010, 05:02 PM   #4
I found the fuse!!It is a flat fuse that was plugged directly into the back of the unit right next to all the wires that are plugged into it.It was burnt out...I replaced it and the unit is working fine now...Sure saved me a lot of trouble not having to bring it in to the dealer to have it repaired!!!Thanks so much everyone!!It is very much appreciated....
Old 04-19-2010, 05:34 PM   #5
fivecodys's Avatar
Nope!
It was toast.
I have a thread here on what I did.
See 'Concertone replacement Completed" if you want more info.
I'm glad yours was just a blown fuse.
Bill
Air Lift 5000
