You might be out of luck, unless one of the three component inputs defaults to “video in” as some or most used to in the days they did. Try taking the yellow video out from the XZ75 and connecting it to the component input with the “Y” below it. I think it is the one that is green in color. If the TV does not default to video, it may have to be selected by the TV menu settings using the TV remote and selected manually. If it does not default and there is nothing in the menu which can be selected, likely the units are not compatible. The audio connection should be straight forward. Also connecting the video out from the XZ75 into the other two component inputs individually shouldn't hurt anything if “Y” doesn’t work. However, if “Y” does not work, likely the other two won’t either.
