Old 07-12-2016, 07:32 AM   #11
Usually Confused Member
emm-dee's Avatar
Originally Posted by Witch Doctor View Post
You can always run into a lazy employee from the State. But State Police are not lazy, they could just pull you over to spot check if it was. Why risk your life and others as it is just unsafe to travel in a underwater tunnel. I'm glad you turned yours off, Thank you. God forbid something exploded in a tunnel. If the fire doesn't get you the smoke will.... To some it seems as just a big inconvenience "HOW DARE THEY MAKE SUCH A LAW" It's there for a reason. As Oakman pointed out..
You're welcome. I don't have any problem with the propane rules. There are a lot of sorta exposed lines that can easily be damaged even in a minor accident or even a tire blowout. I know the bottle valves are supposed to shut off if a leak is sensed but that's not foolproof. Even a minor discharge can create a major problem.
The propane is only off for a short time and I don't think the ice cream will melt. At least the CBBT has pulloffs at the exits so you can turn the valves back on.
At some point during every day you suddenly realize nothing else productive is going to happen the rest of that day. For me, it usually occurs around 9 am.
Vengeance 25V (the Harley needed a home)
emm-dee is online now   Reply With Quote
Old 07-12-2016, 12:36 PM   #12
asquared's Avatar
Originally Posted by Mr Havercamp View Post
I remember that but any vehicle can catch on fire and burn in a tunnel. As far as the Chesapeake Bay Bridge Tunnel I was aware they want the propane turned off but at least you can transport it through.
I don't know. While I'm not going through a tunnel with my 40 or 60 pounds of propane I am surrounded by a hundred other vehicles full of gasoline in tanks that are structurally weaker than a propane tank.
I don't ever recall reading in any RV forum or hearing first-hand of anyone who was fined at any of those tunnels. I have heard of people who were asked if they had shut off their propane at the Chesapeake Bay Bridge Tunnel but they weren't physically checked.
I don't think they're too worried about enforcing it in Baltimore.
Usually mentioning propane and tunnel in any RV forum eventually turns into a huge fear-mongering Festival
I personally know a fellow FRF member who was caught and fined a few years back. That was why I raised the question seeing others go through unchallenged. Thanks for the responses.
<a href=http://i62.tinypic.com/28rp645.jpg target=_blank>http://i62.tinypic.com/28rp645.jpg</a>
2014 Sabre 34REQS-6
asquared is offline   Reply With Quote
Old 07-14-2016, 06:29 AM   #13
mrmichael's Avatar
I just recently came through Virginia and at the tunnel on 264 in Va beach had to,pull into an inspection area and the employee watched me turn off the propane valve on our MH. I just left it off for the ride from there to the Chesapeake Bay Bridge tunnel where they only asked if it was off. Seems silly but it's their rules
Other Motorhome
2013 F-150 Eco-Boost V6
mrmichael is offline   Reply With Quote
Old 07-14-2016, 06:42 AM   #14
(Dry Huunday)
DreiHunde's Avatar
And it's a pretty simple request, too!
Beau & Sue
FurKid Express
2015 Coachmen Catalina 303RLS
DreiHunde is offline   Reply With Quote
Old 07-14-2016, 07:21 AM   #15
Seems to me I read where propane being heavier than air, will settle to the bottom of tunnels that go under water, where as tunnels that go through mountains, (Pa Turnpike, Pittsburgh) are either designed with a hump in the middle or are on some sort of slope, so the propane will eventually exit via gravity.
"DON'T FORCE IT - GET A BIGGER HAMMER'
"Paul & Laurie"
2013 Columbus 340 RK
2013 F350 Dually 6.7 Diesel
Paul M is offline   Reply With Quote
Old 07-14-2016, 07:23 AM   #16
One more thing about gravity,
"Its not just a good idea, Its the law"
"Paul & Laurie"
Old 07-14-2016, 12:49 PM   #17
Witch Doctor's Avatar
Really the man at I-264 was doing his job it happens to me everytime, The guy at the Chesapeake bay was not doing his job, by Virginia law, he should be fired. LAZY *****. PS: and I live in Virginia and just went through the tunnel today, They checked to make sure it was off going to Newport News. Took the bridge back to I-258
Rockwood #8289 WS 2012
F250 6.0 / Husky 16k
With 4 point leveling system
