04-13-2019, 08:19 AM
Bridge/Tunnel Advice
We will be in the Washington DC, Delaware, NJ and Maryland area in May and would like some advice on Bridge and Tunnels to use or avoid. The other question is about LP, I run the frig while moving, is this a problem in tunnels? Thanks
04-13-2019, 08:22 AM
Just have to,have the propane off going through the tunnels other then Baltimore. No propane in their tunnels!
04-13-2019, 08:23 AM
I can’t answer which tunnels up there to avoid, but I can answer the propane question.
All the tunnels in the Hampton Roads region (four of them) all require RVs and camper trailers to stop for inspection to confirm that the propane is off. I stop beyond the tube and turn it back on.
Joe
Current: 2022 Keystone Cougar 26RBS
Past: 2020 Rockwood MiniLite 2205S
Past: 2018 Flagstaff MicroLite 21FBRS
Past: 2005 Flagstaff Classic 625D
TV: 2016 Ford F-150 3.5 EcoBoost
04-13-2019, 08:32 AM
Don't recall ever seeing anything on bridges, but yes as many will tell you tunnels are a different story and require propane to be shut off.
04-13-2019, 08:37 AM
Get yourself a RV GPS and program in the trailer parameters, for the most part this will keep you safe.
I have one and my GPS has never steered me wrong when pulling my trailer. Others have claimed to have issues so, I can't say for sure. I have owned the same brand, 2 different models, for 8 years and I have never had an issue with either unit I owned.
I have pulled out east and out west using my GPS and I have been extremely happy with the results. My trailer is 13'-6" tall and carries two 30-LB propane bottles, I have been warned on bridge height several times. Especially when I forget to switch between RV mode and car mode when not towing.
Jim W.
2016 34RL CC; 2008 Ram Mega Cab 2500HD, 6.7L, 68RFE 6 speed, 4X4, Smarty S67, TDR 145K+miles
04-13-2019, 08:41 AM
What's your preferred brand?
04-13-2019, 08:55 AM
A32Deuce has it right. Go around Baltimore.
2018 Surveyor 264RKLE
Retired
Location depends on weather and state plandemic rules.
Most coincidences are carefully planned
04-13-2019, 10:58 AM
And stay out of the express lanes around the DC beltway, they are restricted to two axle vehicles and buses only. (They are toll roads too).
HTT: "EscapeII" 2016 Shamrock 23WS (current)
PUP: "Escape" 2010 Rockwood HW 277 (gone)
TV: "Gill" 2022 RAM 2500
Just us gals (me, Sis and our daughters)
We spend alot of money to go sit in the woods
04-13-2019, 12:50 PM
I have a Rand McNally RV GPS 7730 model with life time maps. The GPS map data base is updated for free with life time maps. My unit is at least four years old.
Hhere is a link to the latest version: https://www.randmcnally.com/electronics/rv
Jim W.
04-13-2019, 01:08 PM
I have same model and often have to ignore its directions to keep from ending up on city streets or other routes . It will eventually recalculate. One time going north on I95 it took me off and past the navel yard.
04-24-2019, 01:23 AM
Green Horn
You need to take 695 around the tunnel in Baltimore, puts you on the key bridge
04-24-2019, 06:33 AM
Thanks to all, I am making notes
04-26-2019, 07:25 AM
NJ requires propane to be shut off while driving throughout the entire state. Not sure about the other states. You'll have to take 695 around the tunnels in the DC area - no propane tanks allowed.
Check your locations for gas, there's not a lot of large gas stations in that area so find a spot prior to DC or it can be a while (unless you're comfortable with small gas stations).
