09-01-2017, 08:50 PM
Carolina Carports
Here is a photo of the incline for my "never moves" Cherokee Lite A28+ camper. I tried all the ideas suggested here at FR and my husband even contracted a roof man to come redo the roof.
I have given up! Now I have a contract with CC and am wondering if anyone out there had the problem I face. It is on an incline and cannot be moved. Please get back with me about ways to get the "left" side of trailer one foot taller than "right" side of the trailer leveled.
This is a photo from our first delivery of the camper. It is now leveled and needs a carport. Thanks so much for your information!
09-01-2017, 09:18 PM
Not sure what you are looking for?
Are you looking for a way to level your trailer or a carport?
What is a Carolina carpet?
2015 F-250 FX4
09-01-2017, 09:42 PM
Please what is your question??? You say the trailer is now level and needs a carport?? . I assume that you were trying to say Carolina Carports??
We all will try to help.
2005 Dodge 3500 Cummins
2017 Wildwood Lodge 4092 BFL
1966 Mustang GT
1986 Mustang SVO
09-01-2017, 09:51 PM
So.... The pic is from 2011. Is this post a scam or just something to test our sobriety? And why was the roof redone and what relationship is that to leveling and a carport? I need to lay down...
Scott and Liz - Southern NM
2007 Chevy 2500HD Duramax
09-01-2017, 10:25 PM
Yes, it is carport.
I have leveled the unit. The photo is before it was leveled. Now that it is leveled on this incline, the back (left) is nine feet above the ground level and the front (right) is only 8 feet above the ground level.
It may be that CC will not put up the carport on an incline. Has anyone taken an incline to level ground? Thank you.
09-01-2017, 10:28 PM
The roof was redone because water gets into the camper. A carport will prevent snow build up and water puddling to "hopefully" eliminate water on the inside of the camper. Thanks so much if you have any experience leveling the ground or with Caroline Carports.
09-01-2017, 10:50 PM
Ah, thanks for the details. I would say the folks you need to talk to is Carolina Carports to see what your options are
09-02-2017, 04:39 AM
X2
As far as leveling the carport legs will extend some side to side and come in different lengths but?
I do know that that they sell a lot of carports
1966 Mustang GT
1986 Mustang SVO
09-02-2017, 05:00 AM
Eight Feet and Nine Feet above ground level? How on Earth do you enter this "Tree House"? I think all would like to see a "After Pic's" of this "Level Job"! Pic's would HELP to figure out the next move to build a "Carport Cover" over this TT! Youroo!!
09-02-2017, 05:50 AM
NH Maple Maker
Is this a seasonal site at a CG or is it your own land? If it is your own land have a cement pad poured that is level and at the dimensions needed for the carport. With the TT that far out of level I wouldn't run the fridge or use the slide(s).
Russ
2014 V Cross VIBE 822VRBS
2017 Silverado 1500 crew cab 4x4
09-02-2017, 06:08 AM
Citrus County, Fl.
Having had a carport installed (not Carolina Carports) they do require the site to be level. Mine sits on crushed concrete.
Your only option, since you say it can't be moved, would be to build a stem wall on each side of the TT that would also have lag bolts for securing the carport rails. If this is a true height the stem wall is the only thing that would anchor the carport. Eight feet seems extreme unless you are in a flood zone like on the down slope from a trout stream.
2016 Forester 3011DS
2017 Toyota Corolla SE toad
99 Terry 31G
09-02-2017, 06:15 AM
Thread title edit by site team to reflect Carolina Carports
2011 Flagstaff 831 RLBSS
09-02-2017, 07:54 AM
Carolina Carport's requires level ground. Also I very much doubt they will assemble a carport over the trailer because of possible damages and liability.
You will need to move the camper, level the ground, get the carport put up, put the camper back.
Your other option would be pole barn type construction with roof only. That could be done on unlevel ground but you will still need to have the trailer out of the way to build it unless you do the construction yourself.
(Previous) Coachmen Mirada Select 37RB
(Previous) Coachmen Freedom Express 246RKS
(Current)2022 Grand Design Reflection150 226RK
2022 F150 Powerboost Hybrid.
09-02-2017, 08:11 AM
Youroo you gave me a good laugh with the tree house comment.
To the OP... we can't help you.
Your description of 8-9 FEET ABOVE ground level makes no realistic sense.
Unless you provide detailed photos and better information, we are simply guessing.
Best of luck with your project.
Days Camped ☼ '19=118 ☼ '20=116 ☼ '21=123 ☼ '22=134 ☼ '23=118☼ '24=86
09-02-2017, 06:01 PM
I need the carport six feet above the roof so the Dometic can be maintained. They told me to measure from ground to roof. That is what I measured. I will take my camera next week and post the latest photograph. Thanks for your interest.
09-02-2017, 06:05 PM
This is on the res. I have a lease. Your idea seems appropriate. Thanks so much.
09-02-2017, 08:32 PM
I just ordered one for some covered parking here. I was told that the adjustment was up to 6" over the entire length of the carport. So based on what you're saying of having a foot difference front to back, they will require you to level it further. I would call them to be sure.
09-02-2017, 08:41 PM
My carport was not with Carolina Carports, but they required no more than 4 inches out of level front to back or side to side.
Tuckerdog1
2016 RAM 2500 Cummins SLT Lone Star 4X4 LB
2016 Windjammer 3029W Platinum
I'm not an expert. But I play one on the internet.
You live & learn or you don't live long.
If you don't punish your children, life will.
09-06-2017, 04:48 PM
My carport is the same as the company you're looking at. A level site (within several inches) was required for the warranty. They will probably install yours like you want it, but void the very short, almost worthless warranty. I think 6' is too much height over the RV. Mine is about 4' and I just crawl around to do maintenance. Lower is better as far as protection from the elements, and from wind.
2011 Sabre Silhouette 260BHS
2017 F-350 XLT CC DRW 6.7L
