Old 11-19-2012, 07:58 AM   #1
Full hookup cg naer Fostoria,OH
We will be traveling through Fostoria OH in the spring. Does anyone have a full hookup campground they's recomend??
Cathy & Jeff
Midland, Michigan
2013 Sabre 32RCTS / 2012 Ram2500 Hemi
SimchaSabre is offline   Reply With Quote
Old 11-19-2012, 09:23 AM   #2
Gizmo0706's Avatar
Where are you traveling to/from? I only ask because I am originally from that general area and know of some CG's close to Fostoria but didn't know how far off the path you were willing to go.
Gizmo0706 is offline   Reply With Quote
Old 11-19-2012, 09:28 AM   #3
Most likely from Mid-Michigan by way of Toledo. We plan on spending a few days is Fostoria train watching.
Cathy & Jeff
Midland, Michigan
Old 11-20-2012, 05:13 AM   #4
Gizmo0706's Avatar
The campgrounds that we stay at are probably a half hour from Fostoria, I have never had a reason to go there! We have stayed at TeePee campground near Carey and a campground near Vanlue which I can't remember the name of. Both are private and have some full hook-up sites. We usually are visiting family when we are back in that area so the campsites are just a place to sleep for us, hopefully someone else will chime in with better CG experiences for you.
Just a side note, I work for CSX and watch trains all day, I got a chuckle when you said you wanted to watch them for fun! Fostoria is nothing but a railroad with houses so you should be in heaven!
Old 11-21-2012, 09:00 AM   #5
fyi... I am a model railroad person and we go to several train shows each year. The "Fostoria Rail Preservation Society" usually will usually have a booth set up promoting the "Iron Triangle" area to Railfans.
We have 2 daughters that live in the Indianapolis area and plan to take the camper there right after the spring... and in rv terms...Fastoria is (nearly) on the way so we thought we'd stop over to check it out.
As a CSX employee would be treated quite well, so you should go sometime.
Thanks for the CG info.
Cathy & Jeff
Midland, Michigan
