08-19-2015, 04:00 AM
GPS
I am looking to get a new GPS. My nuvi200 does not do trucks or RVs. I have a 2006 F250 4x4 King Ranch with commercial plates and a 2014 Primetime Crusader 260RLD 5th wheel. Not able to use my pickup truck on parkways in New York even without camper. Have not taken camper off Long Island yet. Looking to do so next month. Looking for one GPS that does my truck, 5th wheel and my car. I like the RV760 but the propane thing will be a problem. The dezl760 would take care of the propane but gives me settings more suited for a tractor trail truck. I like the RV one with all its RV info vs the dezl and all its truck stops and truckers info that i don't need. Does anyone have any suggestions?
Prime Time 2014 Crusader 260RLD Touring Edition
2006 F-250 4x4 King Ranch FX4 6.0 Powerstroke Diesel
Don & Katrina + Copper the Beagle
Nights camped 2012 = 48, Nights camped 2013 = 46, Nights camped 2014 = 47, Nights camped 2015 = 49, Nights camped 2016 = 48, Nights camped 2017 = 51,
Nights camped 2018 = 50
08-19-2015, 04:20 AM
Scott & Vicki
2018 Silverado 3500HD Dually 6.6L Duramax/Allison
2018 Columbus 366RL 1492 Edition
Camped 2012 19, 2013 110, 2014 129, 2015 97
2016 93, 2017 79, 2018 84, 2019 59, 2020 0,
2021 4 reserved
08-19-2015, 04:24 AM
From what i am being told it does not take care of the propane. In my travels there are tunnels that you can not take propane through. Was my information i was told incorrect?
08-19-2015, 04:25 AM
Then maybe try the Rand McNally one, I am not sure which one tells about propane
Scott & Vicki
2021 4 reserved
08-19-2015, 08:00 AM
You can take propane in tunnels, the propane is supposed to be turned off is all
08-19-2015, 08:09 AM
Just bought the dezl 760 and it does not deal with the tunnel/propane issue. It will handle your rv dimensions, etc.
08-19-2015, 09:37 AM
I think if you use the hazard setting it covers your propane.
2015 Siera 377FLIK
2014 Ford F350 KR
Maggie the new Chihuahua
Cricket the Chihuahua RIP
Steve & Jojo
08-25-2015, 09:52 AM
I purchased a magellan rv9165t-on. It's awesome. It will do everything you want +. I got a reconditioned unit on Amazon for half the price of new and it works perfect. Love it and wouldn't think of leaving without it.
08-29-2015, 07:38 PM
spock123 - You cannot take propane through any of the tunnels that connect to NYC, nor on the lower levels of bridges, such as the GWB.
2008 Forest River/Flagstaff M-205 Mac
2006 Toyota Sequoia
08-29-2015, 07:40 PM
I stand corrected, you can set it to truck and compressed gases and it will route you around tunnels that are restricted.
02-15-2016, 11:16 PM
Outofthetent is absolutely correct
2016 Forester GTS 2801QSF
2011 Jeep JK Toad
Habitual RV Modifier
02-16-2016, 08:22 PM
I think you are wrong. I looked at what you can take on a RV and you have to have more than 2 30lb tanks. I think most people see no LP and they think about campers but the regs are for trucks with placards. It says in a RV that under 220lb is exempt
02-16-2016, 08:43 PM
Who Dares, Wins
Either way I do not think I would want to even think about navigating NYC with an RV or TT!
2015 Chevy HD D-Max
2022 Impression 315MB
02-22-2016, 11:15 PM
They are correct, NY says no propane at all lower level of GWB and tunnels. I asked if it could b shut off since I travel with the motorhome frequently across GWB. I drove through Baltimore tunnel 2 weeks ago with a car, police had a class A pulled over and they didn't seem happy. I was stuck in traffic jam, I wasn't happy either.
02-22-2016, 11:47 PM
3 times I drove through NYC with a class C and a car trailer, 52 ft. long. Other than traffic/drivers, no problem. Class C or A have DOT tanks and according to MD DOT are permitted in tunnels. I have run the Balt. tunnel several times with tank off. Not knowing why he was stopped only speculation. Could have broken down.
02-23-2016, 12:02 AM
Not quite correct regarding NYC, but it's pretty well hidden - see the Red Book which is issued by the Port Authority of NY and NJ which administers the bridges and tunnels. See p. 5 (of booklet not PDF pagination) - flammable gasses are Class 2, Division 2.1. See p. 13. See the note on p. 13, Materials of Trade (MOT) are allowed here. The definition of MOT is on p. 33 which seems like it doesn't apply, but it carries over to p. 34 where there is this note:
Division 2.1 or 2.2
DOES A CAMPER/RV MEET THE REQUIREMENTS FOR M.O.T
• Not over 100 kg (220 pounds) in a cylinder, or
• Not more than 70 gallon water capacity for a non-liquefied Division 2.2 material
with no subsidiary hazard in a permanently mounted tank manufactured to the ASME Code.
Other limitation
• Aggregate gross weight of all materials may not exceed 440 pounds
[I presume that LIQUIFIED petroleum gas does not qualify for the "non-liquefied" exception but should meet the first one, <220#]
[the proviso "with no subsidiary hazard..." appears to apply to both the way it is written in the booklet after both bullet point]
[note the key term: "permanently mounted" - this would exclude TTs as well as any auxiliary tanks brought along for the ride]
If you are daring enough to take an RV into NYC, you might want to bring a copy of the Red Book along or the key excerpts because chances are good most police or PATH officers don't know every little detail.
I will say I have driven a car + U-Haul trailer right through NYC and it wasn't so bad. However, there are some streets where you may find a very tight squeeze and if you can't get through and have to back up . . . you might hear a little bit of car horn honking! Also, just go ahead and expect every driver to cut in front of you. Once you know and expect it, it just becomes part of life.
2016 FR Forester 2401R
Towing 2014 Honda CR-V
02-23-2016, 05:35 AM
Problem is everyone interprets the regulations differently including the port authority. With the aggrivation of being pulled over past the,GWB who would want the hassle. Easier to avoid then get in a match with port authority. Since taking directly with them gave a different answer then the book they will give a ticket and let you agree later.
I travel through NY approx 10 times a yr. Traffic jams always, really no problems with drivers.
02-23-2016, 07:01 AM
Who Dares, Wins
If that's the case then someone should tell the Baltimore tunnel people... Police, toll takers, administration, Web site.. Because they all say no to propane! [emoji4]
Sent from my SAMSUNG-SM-G870A using Tapatalk
2015 Chevy HD D-Max
02-23-2016, 07:05 AM
Latest Info from NY Transit Web Site:
2004 JTPA TRAFFIC RULES
Bridge only. House trailers, camper trailers, self-propelled campers, mobile homes, recreational vehicles, and other vehicles equipped with LPG installations for cooking, heating or refrigeration are permitted to travel on the lower level of the George Washington Bridge provided that: (a) the LPG container supply does not exceed two tanks containing not more than 45 pounds LPG capacity each or one tank not exceeding 60 pounds LPG capacity; (b) the containers are constructed, installed, and maintained in
http://www.panynj.gov/bridges-tunnel...green-book.pdf
02-23-2016, 07:09 AM
Who Dares, Wins
God.. Your link is for a green book... Above is a red book.. All these colored books!
2015 Chevy HD D-Max
