Old 08-24-2016, 09:15 AM   #1
Need opinion
First time rver going from Ontario to upper Michigan and taking #2 all the way to Montana. Pulling a 36 fifth.Told DW I was taking a 5gal.container of diesel in the truck in case. She told me that was not neccessary and dangerous.What do you think?
hguld1 is offline   Reply With Quote
Old 08-24-2016, 09:38 AM   #2
SeaDog's Avatar
I think your DW is spot on. Traveling should not be a marathon where you stretch your fuel to see how far you can go. If some of the stretches between available fuel stops exceed your vehicles ability then carry fuel if not no reason to.
Retired Navy
Jake my sidekick (yellow Lab)
2016 Flagstaff 26 FKWS
Old 08-24-2016, 09:49 AM   #3
BandJCarm's Avatar
I always carry 5 gallons diesel in approved container, that won't spill.
It's in back, exposed to air.......
FROG AR-0019-242
BandJCarm is offline   Reply With Quote
Old 08-24-2016, 11:19 AM   #4
Need opion
not planning to make this a marathon but was concerned about distances between stations in some areas
Old 08-24-2016, 11:50 AM   #5
Citrus County, Fl.
GL1800Rider's Avatar
When we had out TT I usually carried a 5 gallon can of gas in the truck bed. Truck has a 29 gallon tank and the V-10 loves fuel.
We had just come thru alligator alley on the way back from the keys and were heading toward Naples on I-75 when we encountered a major traffic back up. I did not need the 5 gallons but we were running on fumes when I was finally able to pull off and get gas.
I feel the diesel is much safer than carrying gasoline around as it has a much higher flash point (126 F vs -45 F for gasoline) although diesel does have a little bit wider flammability range or air to fuel mixture at which it will ignite.
2016 Forester 3011DS
2017 Toyota Corolla SE toad
99 Terry 31G
GL1800Rider is online now   Reply With Quote
Old 08-26-2016, 07:53 AM   #6
I always carry an extra 5 gallons of diesel (in approved container) strapped down in the bed of the truck when on long trips. I've used it a few times in the past when the GPS directed me to a station that either used to have, but no longer has, diesel or I'd have to unhook the RV to get to the pump to fill up. One time I also forgot to fill up before leaving and at 9pm the low fuel light clicked on ... boy was I glad we had an extra 5 gallons with us! Treated properly, diesel isn't an issue to carry. I worry more about the 2.5 gal gas can I carry for the generator.
John M
2013 GMC Sierra 2500DH CC, 4x4, D/A
2016 Forest River Vengeance 25V TT/TH
johnm1 is offline   Reply With Quote
Old 08-26-2016, 08:38 AM   #7
Jim34RL's Avatar
We have traveled out west and up into Michigan pulling our 5er. We use two paper books that are sold both in stores and on the internet. The books help us locating diesel friendly fuel stations when pulling our 5er. They are called "The RV'ERS Friend" and "The Next Exit". The RV'ERS Friend covers non-interstate road ways and list stations by cites/towns. The Next Exit covers interstate road ways. Both are worth the cost and are updated yearly.
We plan our fill-ups about 250 to 300 miles apart; so we never run out of fuel. Out West I would fill-up more around 250 miles or so. On my truck I have a 34 gallon tank and get about 11 MPG when pulling. So the tank is around 1/4 to 3/8 full when we stop for fuel.
Jim W.
2016 34RL CC; 2008 Ram Mega Cab 2500HD, 6.7L, 68RFE 6 speed, 4X4, Smarty S67, TDR 112K+miles
Old 08-26-2016, 08:44 AM   #8
Jim34RL's Avatar
Diesel will not explode like gasoline; this is not like the HOLLYWOOD movies it is diesel fuel.
Jim W.
Old 08-26-2016, 08:49 AM   #9
Jimsue's Avatar
I use a yellow Jeri can for Diesel and a green one for unleaded gas, strapped to the bed of my F350. Tank only holds 26 gal and there are stretches of roadway that push the limits of my anemic capacity.
Extensive research showed me that these are the best Jeri Cans out there ( beware of cheap imitations on Amazon or eBay or Harbor Freight Etc)
http://www.lexingtoncontainercompany...erry-Cans.html
2015 F350 Lariat Crewcab DPS SWD 4x4
2013 Sabre BKOK 31
Demco Hijacker Autoslid
Renogy Solar Suitcase
Progressive Industries EMS
Sea Eagle 420 Tandem Inflatable Kayak
Jimsue is offline   Reply With Quote
Old 08-26-2016, 09:17 AM   #10
Gasoline typically doesn't explode, either. Every explosion you see in the movies was rigged.
2011 Traverse LT, 3.6L, FWD
rockfordroo is online now   Reply With Quote
