Old 04-25-2014, 02:09 PM   #11
campman1's Avatar
I bought a 2014 Grey Wolf last year from a local dealer, They tell me the antenna on it is the best one one the market, but when going caming the first 6 times, I could barely get one channel. Dealer tells me that is is because im probably in a remote area, but I went camping with a freind of mine, same campground, right next to eachother who has a 31' (can't remember the brand) and he got like 40 digital channels, whats the deal? is it I just have a crappy antenna on the Grey Wolf and he has a better one that came with his.. any suggestions??
Thx Tuna
campman1 is offline   Reply With Quote
Old 04-25-2014, 02:10 PM   #12
Originally Posted by Cajun Po-Boy View Post
Nice...was that by chance two FRF members at the same SP and next to each other?!
Yeah, wasn't it lucky for me the that he was?
2014 Crusader 325res Touring Edition
2003 Silverado Duramax 6.6 Dually Longbed 2wd Crew Cab
RickV is offline   Reply With Quote
Old 04-25-2014, 02:25 PM   #13
Thx Tuna
I have a app (this one actually works) called TV Antenna Helper it shows you which way to point your antenna with different color lines green for good to red for good luck showing which way to point your antenna. We were camping last month in semi fringe area I had about 15 channels my friend was getting one. I said look where my antenna is pointed and point your's that way. He did and rescaned and 15 too. Another thing could be that there is a small green led button where your cable goes to the TV I think it controls cable vs ota.
BTW here all the lines are red.
Old 04-25-2014, 02:27 PM   #14
campman1's Avatar
Yeah, i did the whole checking the green button thing, , thing is the crappy antenna my camper came with is a permenant one, its not one of those you crank up and down, its a little UFo shapped one, piece of crap if you ask me, but the dealer told me different, porbably sold me a bum steer.
Old 04-25-2014, 02:49 PM   #15
They make a coaxial cable tester that checks for continuity, there could be a break in the cable. They aren't to expensive. As a matter of fact I got an email today from solid signal they have a flash sale on em Perfect Vision Pocket Cable Tester (PVPTTWO) from Solid Signal
Old 04-26-2014, 04:37 PM   #16
We were at High Falls the end of March. Started out in site 82 and could not get a single channel with satellite or antenna. The second day we moved to the other side of the loop - site 68. Put out the satellite and got great reception. I think it is pretty much hit or miss there.
2012 Flagstaff 831FKBSS
2011 F250 Diesel
anitag is offline   Reply With Quote
Old 04-26-2014, 04:43 PM   #17
Herk7769's Avatar
Can you pm me a link to the campground and I will see what Antennaweb.org puts up and snip a photo to post.
This one in GA?
76 High Falls Park Drive
Jackson, Georgia 30233
If that is the correct address, it is too far off the beaten path for OTA reception with a roof mounted antenna.
HAM CALLSIGN - KC3FFW
Old 04-29-2014, 08:47 AM   #18
This one in GA?
Yup that is the place .
Old 04-29-2014, 09:09 AM   #19
Herk7769's Avatar
Bummer. Take some DVDs.
Old 05-06-2014, 08:37 PM   #20
CMSgt. (Ret) Charlie Brown
CMSgt (Ret) Charlie Brown's Avatar
Thx Tuna
Make sure you have the booster turned on. Should be right close to antenna connections by TV.
CMSgt (Ret) Charlie Brown is offline   Reply With Quote
reception, tv reception
