Old 08-17-2015, 03:51 PM   #1
Travel route
Traveling from Winston Salem to Knoxville. Have a 38' 5er with 2500hd duramax diesel. Anyone traveled this route, are the smoky mountains more than I can handle?
delgal is offline   Reply With Quote
Old 08-17-2015, 04:15 PM   #2
Citrus County, Fl.
GL1800Rider's Avatar
I have taken I-40. Only issue you may have is climbing Black Mountain. You should be ok but will probably drop to 35 going up the mountain. What ever gear you drop to going up you will need going down. I-81 is supposed to be a little quicker per Google Maps but it shows a lot of construction. I have never been that way.
2016 Forester 3011DS
2017 Toyota Corolla SE toad
99 Terry 31G
GL1800Rider is offline   Reply With Quote
Old 08-18-2015, 10:22 AM   #3
jevanb's Avatar
You will climb them at speed but use the tap shifter (6 speed equiped) before the trans needs to shift, keep up the rpm, I pulled from Tampa to MI up 75 and I never slowed below 65, I also ran 70 thru Colorado and Utah and the same, just keep up the rpm. I have did both trips with a stock truck and not so stock.
Sent from my SCH-I545 using Tapatalk
2012 Wildcat 344QB
06 LBZ ,CC 4x
lots of mods
Superglide
jevanb is offline   Reply With Quote
Old 08-19-2015, 08:56 AM   #4
When I go that way I run 52 to I-77 to I-81. I hate going thur the gorge. I don't worry about Black Mountain my Silverado 3500HD pulls it just fine, I have a 35ft Cedar Creek
2015 Cedar Creek 32RL
2012 Silverado 3500HD SRW
http://www.forestriverforums.com/for...ignhavefun.gif
spock123 is online now   Reply With Quote
Old 08-19-2015, 09:02 AM   #5
Have pulled it many times from Concord with my weak kneed Silverado 1500 with no problems. Just get in the truck lane and follow the semis. I pass a few and get passed once in a while.
travel
