Originally Posted by JEM
Best route around Balitmore tunnel, I will be going south from NJ
I guess you don't like the tunnel? you can go that way as long as your propane tanks are turnd off.
The other way you can go to pick up I-95 South is to go around the Baltimore Beltway in the direction of Towson and pick 95. Do have a map or a gps, if you have a map it will give you the exit number to I-95 or you can advance your gps to the route it is taking you.
The beltway route in this direction (Towson) are a lot better as far as road conditions then the other way around the Baltimore Beltway.
If you use the tunnel you will stay on I-95 South once you get to the tunnel you will pick up I-895 South once you come out of the tunnel then you will pick up I-95 South again, the reason for this is because this the connecting link between both ends to I-95 to I-695 the Balimore Beltway to go around the tunnel from each end using the the Baltimore Beltway. The Baltimore Beltway runs in a circle around Baltimore City.
