Old 01-09-2009, 07:07 PM   #1
04 Tsumani and toad question
My planned configuration
We just bought an 04 Forest River Tsunami with a side mounted radiator. I have an 03 Toyota Tundra 4WD (6200 lbs +/-) that Iím configuring to use as a toad. I also have an 05 Goldwing (800 lbs +/-) that I want to bring with us.
Iím having a Roadmaster Blackhawk 2 installed on the MH and installing a Brakemaster on the toad for supplemental braking. The Tundra is also getting a driveshaft disconnect from Remco.
I also have an 05 Honda Goldwing that Iíd like to mount onto the rear of the coach with a Cruiserlift by Fastmaster products in order to not have the GW interfere with the toad in any way.
The coach has a receiver that the data plate rating the receiver (Reese) at 20,000 lbs.
How does this combo sound to you road warrior vets? Can/should I do this combo? Are there alternative solutions that I should look at to still be able to accomplish my goal for bringing the Goldwing with us?
Thanks for the time and the help.
Ken
Luvdiving is offline   Reply With Quote
Old 01-09-2009, 10:20 PM   #2
NWJeeper's Avatar
I would ask Fastmaster products the question as they are the ones that have the expertise with this issue. I would have to guess that you will be just fine. Best to talk to the experts though.
Ed & Wendy
www.nwjeepn.com
