Old 11-09-2015, 07:45 PM   #11
If it is just used for the bikes and you have the right tools and all, you could drill and tap a 5/16 or 3/8" hole for a pinch bolt that should take about all the play out.
hdmtnrider is offline   Reply With Quote
Old 11-09-2015, 07:55 PM   #12
Bluepill's Avatar
Replace the hitch pins with 5/8 inch bolts, nuts, washers. Tractor Supply is a good source. Makes it rock solid.
I carry a 300# motorcycle on the back of my camper with a 2" hitch of my own design.
2008 Itasca Meridian 37H
Old 11-09-2015, 07:58 PM   #13
Here are a couple of anti rattle devices.
https://www.etrailer.com/dept-pg-Hit...ti~Rattle.aspx
I have a 1 1/4 to 2 inch adapter for my bikes. I have two clamps that lock the rack into place.
2015 Sunseeker 3170ds
TakeItEasy is offline   Reply With Quote
Old 11-10-2015, 06:21 AM   #14
they sell a anti wobble for your hitch at rvupgrades
wire1946 is offline   Reply With Quote
modifications
