Old 05-27-2016, 11:14 AM   #71
CWSWine's Avatar
Originally Posted by porkchopjack View Post
You guys need to go look at the New 2015 and 2016 F150 tow guides they are 600 to 1000 lbs heavier for the ECO boost now. The tow police will now be having a cow for sure.
I did what you said and looks like the 2015 and 2016 GVWR went down from previous years. It looks like the curb weight went down also making the payload about the same as previous years.
Past years the HD payload had a 8200 lbs GVWR and now the highest is 7850 for the 2016 model year but again it is a wash since the curb weight decease with the aluminum body. Must be some other limiting factors to not keep the 8200 GVWR in the 2016 model year.
I'm just not seeing a 1,000 lbs increase in payload that you talking about.
2017 Fleetwood Discovery LXE 40D Diesel Pusher 41 foot. CC 5740
2017 Solitude 310GK-R Pick Up Oct 24th.
2016 GMC Denali 1 ton Cargo Capacity 3722 lbs
Sold 2016 Keystone Montana 3711FL
Sold - 2015 Crusader 315RST 5th Wheel -
2015 Ford F350 SRW Cargo Capacity 3744
CWSWine is offline   Reply With Quote
Old 05-27-2016, 01:23 PM   #72
CaptnJohn's Avatar
I have seen several F150s towing 5ers. The latest at the NC Good Sam rally. All I recall now is the 5er was gray in color and had LITE on the side. I looked at Keystone 5ers for a friend under the 1/2 ton series. The lightest was 27' with a 1290 pin. There were 5 or 5 models with pins under 1500#. He bought a 31' with a pin just under 1500.
2017 Montana HC 370BR
2016 F350 diesel
Edgewater 205 EX 150 Yamaha
CaptnJohn is online now   Reply With Quote
Old 05-31-2016, 12:57 AM   #73
mnwild58's Avatar
Ok, on the subject of a F150 ECOBOOST pulling 5th wheels, remember you need a 6 1/2 ft box your pin weights, your gvwr, there are campers out there that are 1/2 compatible, now here's the sticky part, when buying the F150 ecoboost there are only 2 ply tires on the pull vechile and they are not rated for the weights!!!
When we purchased our F150 I put on 10 ply tires on, also to help with the ride I put air bags under rear suspension.
I also when pulling our 5th wheel use the johny bar (brake controller) to help slow the vechile down, it makes logical sense, why wear out truck brakes.
Most important if you don't feel comfortable with your tow vechile choose or step up to F250 or 350.
mnwild58 is offline   Reply With Quote
towing
