Old 10-10-2010, 10:37 AM   #51
Herk7769's Avatar
Originally Posted by donn View Post
Your kidding right?
My 1 ton dually does not have that much and it sure is heck is a lot more truck with a lot more pulling power that any 3/4 ton truck on the road!
I suspect if you look again you will discover it is actually 20K. At lease that was what my 2004 2500HD was.
hate to break it to ya, but I did do some "rounding"
The actual value is: (drum roll)
Gross Combined Weight Rating 24,500 lbs.
http://www.gmc.com/pdf/Download_Brochure_link.pdf
Page seven
HAM CALLSIGN - KC3FFW
Old 10-10-2010, 02:18 PM   #52
Not sure where you are digging up this sort of numbers. But directly from the 2010 GM brochure the towing rating for a 2010 4X4 crew cab regular bed the GCWR is listed at 16K. Now I do know that GM has bumped the numbers for the new body style, but come on now, a 3/4 ton with a GCWR 2000 pounds more than a dually? That is just too far off the truth to be even remotely believable. If you were to tell me that the GCWR was 20K that I could believe. Because that is what my 2004 was rated at.
Old 10-10-2010, 03:18 PM   #53
Herk7769's Avatar
Look at the brochure. Page four and seven. 2500/3500 HD Duramax diesel.
Old 10-10-2010, 10:20 PM   #54
From the 2008 brochure I read it as MAXIMUM towing rating of 12,500 to 15,300. Plus "1 Maximum trailer weight ratings are calculated assuming a base vehicle, except for any option(s) necessary to achieve the rating, plus driver. The weight of other optional equipment, passengers and cargo will reduce the maximum trailer weight your vehicle can tow. See your Chevy dealer for additional details.depending on body configuration."
So anything and everything you add to the base vehicle reduces your actual trailer towing capacity pound for pound. Sorry to burst your bubble. I have been through this and there is no way a 2500HD GM product can handle a fiver that weighs 15K. Pin weight of that much will put you so far over the GAWR it is not even funny.
My 13,350 pound fiver hitched, my 2004 D/A scaled 10,500 pounds. A whopping 1300 pounds over the GVWR. And believe me I knew every pound of that was behind that 2500. The only way anybody can claim the sorts of numbers you are posting is to believe the salesman and have not actually scaled their truck loaded ready to camp. I have and I understand what I had. That's why I no longer own a 3/4 ton truck and instead drive a dually.
Old 10-10-2010, 10:41 PM   #55
Originally Posted by crocus View Post
What worries me is the overloaded trucks I see on the road with their butts dragging and the front end pointing up in the air. I can't imagine what it must be like driving like that.
Some TV/5er combos don't look out of place to this untrained eye, but there are some 5ers (Titaniums?) that to me dwarf the average pickup. Meeting 1 of those on the highway & it looks like an S-10 towing a 53' dry van.
2017 Chevrolet K2500HD, Husky W/D hitch
2009 Rockwood 2106 Mini-Lite
Nights camped 2010: 21
Nights camped 2011: 17
Nights camped 2012: 8
https://inlinethumb45.webshots.com/3...600x600Q85.jpg
revrnd is offline   Reply With Quote
Old 10-11-2010, 05:04 AM   #56
Herk7769's Avatar
I am so sorry. I thought you only wanted the Gross Combined Weight number for a Sierra HD with Duramax diesel. I had no idea you would change the subject to make a point that does not apply to the post.
I refer again to the safe towing calculator at changing gears I posted earlier that you also did not bother to read.
Fifth Wheel Weight Calculator
Old 10-11-2010, 05:05 AM   #57
Herk7769's Avatar
Thanks for trying to lighten this up.
Old 10-11-2010, 05:19 AM   #58
Infractee
You ain't kiddin'! While I was coming home from work yesterday saw bunches of TT's heading home. There was a late eighties or early nineties extended cab SRW F250 pulling a ginourmous 3 axle FW! When I first saw it I could have swore it was a Ford Ranger!!
RhoZeta is offline   Reply With Quote
Old 10-11-2010, 09:51 AM   #59
Does anyone know what the GVW of the average Titanium is?
Old 10-11-2010, 10:01 AM   #60
Herk7769's Avatar
It totally depends on the options ordered with your trucks.
Check here for your specifications.
Theeve Titanium Truck Co. 2010
